Having some trouble with the ol' TFSI. Intermittent, but seems to be happening more often as time goes by.
On idle, cyl 4 will show some misfires, more after a long drive. Maybe 10 every 30 seconds or so.
Driving around town or low throttle seems to be OK but as soon as you go medium to high throttle it will hesitate then go then back to hesitate again. No strange noises and no warning lights on the dash. VCDS scan shows no error codes.
I've done some logging with VCDS and things like Boost Requested and Boost Actual match very well, so I don't think the DV has gone.
3 of the coil packs were replaced last year at SEAT, but I got another from Dave @ SERE (Thanks mate!) and put it on cyl4 with no difference. (Part codes were the same on the old and new).
Spark plugs are NGK, replaced about 18 months ago and look fine.
http://1drv.ms/1o151rd
I have ordered some new ones just in case its faulty in another way.
Lambda figures look off to me but im not sure, can anyone confirm?
I have added my VCDS log http://1drv.ms/1o151rd - Marker 6 is where I did a 3rd gear WOT run until I ran out of road
Before marker 7 & 8 where when I noticed the hesitation.
I did a reset in VCDS so these values are after about a 20 minute drive.
I had a good read of this thread http://www.seatcupra.net/forums/showthread.php?t=372678
Should I suspect a faulty injector in cyl 4?
Dave
Code:
13:21:16 Group 032: Lambda Regulation
0.4 % Lambda (Idle) Self-Adaptation
2.3 % Lambda (Partial) Self-Adaptation
13:21:16 Group 033: Lambda Regulation
-4.7 % Bank 1 Lambda Control
1.48 V Bank 1 Voltage of Oxygen Sensors
13:21:16 Group 016: Misfire Recognition
10 Cylinder 4
Enabled Malfunction Recognition
Dave
