DrewCole
Spannering the Cupra
Oct 19, 2015
696
Braintree, Essex
Did the mk4 seats bolt straight in or was there any work needed? Looks very smart mate. Think it's the best part of the leon having plain black door cards. Easy to change seats without them looking out of place
Sent from my SM-G920F using Tapatalk
Yeah direct fit, sometimes the airbag plugs need changing. These were okay to plug straight in.
So much nicer than stock seat, more bolstered and lumber support.
Sent from my SM-G935F using Tapatalk
Cupra_liam
77
Out of interest what are you doing with your old seats? My driver side is a little tired. I will Deffo be looking for some golf seats in the near future then.
DrewCole
Oct 19, 2015
696
Braintree, Essex
I've put them up for sale as a set at the moment.
I'd keep them but I'd rather not take the space up in the garage!
clag
111
Busy weekend. Passenger side doors resealed, new alternator pulley, new aux belt, sorted a boost leak, simplified vacuum system after removing egr and anti shudder valve. Then washed and polished :)
Stuart09
145
Finally got round to doing the n249 bypass mod. Running sweet.
Sent from my GT-I9505 using Tapatalk
TomkinsFR
21
Led reverse lights fitted
Sent from my HTC One M9 using Tapatalk
Gabster
60
Dorset
I got Audi leather seats from a 3 door A3 s-line half a year ago, just love the support that they offer and the bonus is the small storage compartment in the seat.
Christ what a pain in the arse it was for me to do the plugs... actually I was a bit lazy haha was putting it off for months till I run out of MOT.
I finally done it over this the weekend. I was reluctant to do it because I couldn't find any info on the wiring.
I'm quite happy with myself that I managed to get that vag com vcds working and managing to reset airbag light.
Programmed my key using vagcom so that the horn sounds and lights flash when locking and unlocking :)
Sweet, I want to set up that when I'm turning the alarm on the windows will close automatically, any idea how to get about it?
BrillPhil
BrillPhil
Jan 18, 2016
9
Folksworth nr Peterborough
Sweet
At last tracked down the reason for rough idle on my Mk1 Cupra T. Vacuum leak, split in the small pipe running from main upper breather tube to the inlet manifold. The brake cleaner spray trick gave the clue where to search. Even after all these years I find it hard to understand the plumbing of the 20VT engine. Broke the dipstick guide tube though!
Calumcjm
126
Glasgow
How did you do that? Searching high and low for mine
Sent from my F3111 using Tapatalk
notquiteacupra
18
Well I only bought the car a week ago and have had to do so much to it so far.
Today replaced the air filter, flushed and replaced my power steering fluid, taped up a split brake servo vacuum hose, and finally changed the coolant temp sensor and outside air temp sensor.
Then I sat in and awaited delivery of a new exhaust system from carparts4less.
After this with the steering no longer felling like I'm turning a HGV (due to the power steering fluid level being below minimum) I proceeded to drive to the breakers and acquire a new brake vacuum hose, and then finally to eurocarparts for a pre cat lambda sensor and fuel and oil filter.
Let's just say my wallet is seriously hurting at the minute.
