Il run a diagnostic scan on my car tomorrow to see if theres any fault code. I have no warning lights on my dashDid as you suggested and auto wipers working again, still got the aircon databus error though.
Sent from my SM-G930F using Tapatalk
My vcds has stopped working (drivers issue), ive installed a new tool and this damn thing stopped working. Will test it on my other laptopDid you manage to run a scan?
vcds working on other laptop after installing it.Did you manage to run a scan?
Ive taken blower display in auto mode off, but it hasnt eliminated the fault code. Clearing the 2 fault codes im left with 1I’m not familiar with VCDS but it looks like it’s the same fault as I reported
U1121
This fault will be linked to sunlight sensor error. When deactivating it upon changing rhls sensor, we might ve half completing the deinstallation of sunlight sensor
Try it. Mine ive noticed they will come on at daytime, but sometimes its not even that dark or too sunnyI find that my auto lights are too sensitive when set to normal. I note than in OBD11 it has 3 settings SENSITIVE, NORMAL & NONE SENSITIVE, am I right in thinking NONE SENSITIVE really means less sensitive?
https://forums.seatcupra.net/index.php?posts/4788301Hi. Just about to embark on this retrofit. Is there a difference between the 5Q0955547A and B version of the sensor ? Or is the B just the latest version.?
Thanks for the reply guys. Yes interested in MK7 switch if you have one.If you need an Auto switch, I have a Golf MK7 version available in a few days.
