Yes - i have the same as you and i have lost mirror link.
looked at the alarms after a scan Got a fault code on unit 5F "Checking Software version Management" -
Fault code : B201A00
Status: Static
Priority: 6
To remove the SVM fault code;-
VCDS CODING
1.5F (Infotainment) module, Adaptations, channel: 'Confirmation of installation change'
2. Note your current coding
3.Start Windows calculator and set it to 'Programming mode' and select 'HEX' option
4.Calculation: (current coding) XOR C9D2
5.Change the adaptation channel to the new (just calculated) code
6.VCDS main screen, 'Auto-Scan'
7.Check for fault codes (generated by the update) and clear them (software version, interrupted communication, etc.)
8.Note that VCDS shows your code on the adaptation channel with a space ('xx xx' format).You have to remove the space before you calculate your new code. At the point you enter your new (calculated) code, insert the space again.
EXAMPLE (don't use these values):
•'1A 1A' (original coding of the adaptation channel)
•1A1A XOR C9D2 equals D3C8
•Enter it as 'D3 C8' (with space) on the adaptation channel
•If your original code starts with zero(s) just remove them before calculating (if it's 0AFB for example calculate with AFB)
Thanks - Just tried it and I'm getting 4324 - doesnt look right to me - but maybe it is, I just dont want to enter something wrong,
I get the same value of 43 24 using your 8A F6.
Don't know how to do it with OBD eleven.
