I've followed on from our previous conversation.
I'm using VCDS V2 cable, just upgraded to unlimited VIN.I reckon Walone uses Obdeleven and has a high unit so not identical but I could be wrong on the SVM removal. Obdeleven gets rid of it fine on a high unit.
I am using a MIB2 standard (Navi System - 6P0) and use VCDS 17.8Works fine with Obdeleven on a mib2 high. I know at one point VCDS didn't work, it was an Obdeleven only thing. You need to check that with mib2 standard and version you have I reckon.
I will try to clear faults logs and hard reset unit first. Then i will enter the value on Uppercase and see if it is working or not (Yes i have a space between 63 and 4F).
Adresse 5F: Electr. d'informat. (J794) Labels:* 5F0-035-MIB-STD2.clb
No. pièce Log: 5QA 035 846 Mat: 5QA 035 846
Pièce: MU-S-N-ER H24 0241
No. de série: SEZAZ2R0274151
Codage: 04730301FF0A000011110001000808002F0301D401200100C6
No. Atelier: WSC 02391 785 00200
Jeu de données ASAM: EV_MUStd6C3TSAT 001015
ROD: EV_MUStd6C3TSAT_SE26.rod
VCID: 0108BD9890090B4E85-8054
Unité d'affichage et de commande 1 pour électronique d'info.:
Sous-système 1 - No. pièce Log: 5F0 919 604 A Mat: 5F0 919 604 A
Pièce: ABTm_Std2_Nav H43 1028
No. de série: SEZ8Z9RFT005XY
Support de données:
Sous-système 2 - No. pièce Log: 6P0 919 866 AB Mat: -----------
Pièce: ECE1 2018 --- 0915
No. de série: --------------------
1 Codes défaut trouvés:
2571 - Système de navigation
B126C F2 [008] - Base de données de navigation non validée
Intermittent - Confirmé - Testé depuis RàZ mémoire
Capture:
Etat du défaut: 00000001
Priorité du défaut: 6
Fréquence du défaut: 6
Compteur de RAZ: 190
Kilométrage: 55736 km
Date: 2018.09.26
Temps: 13:22:11
Tension borne 30: 12.5 V
have you changed the coding of anything in vcds ? does the mib actually work with the map sd card ?I will try to clear faults logs and hard reset unit first. Then i will enter the value on Uppercase and see if it is working or not (Yes i have a space between 63 and 4F).
Support de données:
Capture:
Date: 2018.09.26
Temps: 13:22:11
Hi,
I have just updated the navigation version (430 to 915) through the website https://here.navigation.com/europe/fr by selecting SEAT Leon 2016 and download 915 version. But everything is working, navigation is working well, only i have an error on the 5F module (Navigation Database is not valid) due to the update. I try to delete it by the XOR method but still appears. By the way, everything is working, so i think, i will not investigate more time ... but see people succeeded to remove the smv fault, so i don't how it is not working for me.
OK I have read this interesting thread and noticed one post said if you get the correct serial number you can get an SD Card Map update off ebay that will work OK is this right or did I read something wrong ?
My Map box has 6P0.919.866.H and is Version 3 - I saw a Version 5 on ebay with the code 6P0.919.866.R - would that work ?
If you already have a working SD nav card in your system then you do not need a card from eBay!OK I will read through again.... Just been looking on ebay again and I found these below
Would they just slot in ?
Just follow the procedure as mentioned by Tell. Just make sure you do a full backup of the original card!
Also I think you need to use a PC not a MAC.
