demonikx
44
Hello,
I try to install the Ambient foot light in my Ibiza.
I Have car from 2016 with BCM PQ26 Hi4R
I try to find the electric schema in internet for my car but I could not find anything.
Only what I was find that how to activate this function in my car.
VCDS codding
09-central electric long coding byte 17 bit 1 actived
Leuchte10SHUTTER LRB45-Light_Function_A_10 — Ambientelicht 1
My question is how I connect the wires for BCM
When i was talking with someone he says that electric schema from polo 2014 + should help me. If it's true?
Hello,
VCDS codding
Hi! Did you manage to do it? I'm planning on doing it myself with the same BCM. I think I found all the info to do it.
  • N 103 357 06 pin conector
  • Flow Diagram (BCM Conector B pin 45 of 47)
  • OBD11 Codding (not very difficult)
Hi, still under construction.
I find wire and lights kit. My problem was how connect it to bcm, but for the end i find the schemas.
I hope i will have time to do it in near future!
I know how, you have to remove the B plug of the BCM and add the new crimped pin to the 45 pin.
I'm waiting for the pins to arrive (i didnt buy the kit)
11 $ for all this :cheeky:
Okay i done it works, but not for 100% how i can activate menu in multimedia.
when i try to coding ambientelicht 1 option light not work
When i try ti use ambience lighting it works when i open and close doors
I try to activate menu in multimedia front ambient lighting but it bot work for me :-(
Are you codding with obdeleven?
Also, do you have any pics of the wiring from the BCM module?
When you will open connector you will see number of pin on connector
Yeah, I also have the diagram.
1NcC6J8l7EN8hAA6GmoIgOxSBEq-LjwnyErjsqOJFTPIVKJnnlmkH8kUaFJ8y0ZU
The only thing I don't know for sure is the location of the BCM and the ground screw.
I use obdeleven for codding, I think it's more intuitive. Also, I have a PQ26 Hi4R dump of a guy that has footwell oem installed. I can upload it but I don't know if that's going to serve you because it is a obdeleven dump.
