I dont know. But i use hex v2, or vagcan pro for coding. I can code everything.Infact is the same stange tooo
how is possible that you see this 10 module?
Possible that vcds hex2 have more power that ODBeleven?
I'm new to obdeleven, does anyone know why i get the (31) Function not available when i try to enable OPS display?
Nope. Only white and red color. No RGB
Security acces code to activate it.easy fix, got OPS working![]()
Verstuurd vanaf mijn SM-G965F met Tapatalk
You need to login before coding. I think it's called security access, just scroll to it and enter the code,then you code.
No not posible. Its only Active on turnsignals. Brake not posible. Leon 5F its NBA functions. And also dynamic crash flashing. To activate it.@everybody,
Do Have in your Ibiza Emergency Brake Light Flashing actived?
Ibiza dont have dynamic light options like NBA functions, crash&panic flashing etc.Dont know if its the same but here is the coding for the Leon
Activation of emergency lights with sudden braking All models
1 - Module 09 - Electronic control unit. Code (31347)
2 - Adaptation
3 - Dynamic modes of intermittenceUp to MY16 or enter Aussenlicht_Blinkert From MY17 and later
4 - Emergenci alert blinken - (Change value to On)
Read more: http://forum.obdeleven.com/thread/6342/adaptions-spanish-site#ixzz5zzvxBDMg
