Find someone with vcds i do alot of coding. I know what I am talking about...
Coded 2 day seat arona 2019 (same as ibiza 6F) and seat ateca.
Verstuurd vanaf mijn SM-G965F met Tapatalk
Infact is the same stange tooo
how is possible that you see this 10 module?
Possible that vcds hex v2 have more power that ODBeleven?
Maybe that the seat ateca and arona have more modules inside respect the seat ibiza kj !!
Possible that vcds hex2 have more power that ODBeleven?
I dont know. But i use hex v2, or vagcan pro for coding. I can code everything.
I can show more then 5 logs of ibiza 6F.. al have module 10 park/ steer assist. This is the only way to code optical parking system...
This is the coding:
STG 10 (Einparkhilfe) auswählen
STG Zugriffsberechtigung - Funktion 16 auswählen
Zugriffscode 71679 eingeben
STG Codierung -> Funktion 07 auswählen
Byte 2 auswählen
Bit 0 - optische Darstellung Einparkhilfe - aktivieren
Most of the aftermarket sensors, that the dealerships usally install as a "gift", are not connected to the car. So you can't activate the optical parking system. It just won't work.
I'm new to obdeleven, does anyone know why i get the (31) Function not available when i try to enable OPS display?
Hi all, does anyone know if the ambient lighting strips in the Ibiza FR are RGB like they are in the Xcellence? I'm wondering if there might be any coding for it as I have a FR (2019) and it'd great if I could have more colours instead of just red or black
Nope. Only white and red color. No RGB
Dont know if its the same but here is the coding for the Leon
Activation of emergency lights with sudden braking All models
1 - Module 09 - Electronic control unit. Code (31347)
2 - Adaptation
3 - Dynamic modes of intermittenceUp to MY16 or enter Aussenlicht_Blinkert From MY17 and later
4 - Emergenci alert blinken - (Change value to On)
Read more: http://forum.obdeleven.com/thread/6342/adaptions-spanish-site#ixzz5zzvxBDMg
@everybody,
Do Have in your Ibiza Emergency Brake Light Flashing actived?
No not posible. Its only Active on turnsignals. Brake not posible. Leon 5F its NBA functions. And also dynamic crash flashing. To activate it.
Like this on Leon 5F
2 - Adaptation
Ibiza dont have dynamic light options like NBA functions, crash&panic flashing etc.
