A hope so mate . I will let you know if it works or not ... fingers an toes crossed haha
This is what hes took off , an shows what went where
Thanks bud .. i looked at this the other night , its chucked a little more confusion into the mix . Gona give it a bash anyway see what happens . His has t-piece in same place as mines but not sure if hes cut line to fpr aswell , looks like it thought i will give it a go as per mc funbots (how to) after ive done school run lol dont wana be stuck in the drive lol
Late ti the party but The AUQ manifold has extra nipples, which actually makes the whole thing much much easier. Essentially you can remove the whole lot, metal hard pipes, SAI, combi valve, then one line from FPR to mani, one line from DV to mani, plug the rest. No T's into lines necessary.
I kept my plate with the n249/n112 attached and plugged them in to avoid codes. Worked a treat.
The red third line on the right comes from the EVAP system/fuel rail, I just had some hose left over.
