Dont know about this. All i did was disconnect all pipes from n249 ( recirc to valve to vac reservoir to valve to inlet) then run new pipe from nipple to top of recirc
Thanks bud .. i looked at this the other night , its chucked a little more confusion into the mix . Gona give it a bash anyway see what happens . His has t-piece in same place as mines but not sure if hes cut line to fpr aswell , looks like it thought i will give it a go as per mc funbots (how to) after ive done school run lol dont wana be stuck in the drive lol
All done .... took me all of 25 mins cleared fault codes to her for a spin scanned again all clear . Strange though as normally get 3 codes due to decat but all done happy guy . Thanks for all the help mate
Late ti the party but The AUQ manifold has extra nipples, which actually makes the whole thing much much easier. Essentially you can remove the whole lot, metal hard pipes, SAI, combi valve, then one line from FPR to mani, one line from DV to mani, plug the rest. No T's into lines necessary.
I kept my plate with the n249/n112 attached and plugged them in to avoid codes. Worked a treat.
The red third line on the right comes from the EVAP system/fuel rail, I just had some hose left over.
