Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
I’ve changed the Ambient colours on the door cards on my wife’s 2017 Leon Xcellence and when selected the colour does change in them.
The car doesn’t have a digital dash though and I did use OBDEleven.
I would think that it’s a coding issues. I altered the coding manually by adding in the new RGB codes.
Probably is possible, but if it’s a pre facelift, you’d need to check the DRL still turns off when indicatingHi guys, I've done a few bits but really want to find a way to change (increase) the brightness of my side lights - so their brightness matches the DRL. I've not had any luck from the searching I've done, albeit a frantic scan through some pages.
Does anyone know if this is possible and able to point me in the right direction - pre face-lift (15 plate)?
Also having seen a few Leons driving in the dark without their lights on (not sure how as their dash should warn them) the DRLs are too bright for other road users. So expect to be flashed.
I have a '15 plate Leon FR, having issues with one or both wing mirrors not folding. Could well be an electronic issue.
Is ODB11 any good for diagnosing this, ie showing switch/motor fault etc?
OBD11 is different to OBDeleven which only works on Android at the moment.Hello everybody,
I tried to read as much as I could in the 84 pages
I did purchase an ODB11 adapter on amazon, and downloaded EODB-Facile, Auto Doctor, ODB2 Expert and ODB Plus on my iOS
I managed to connect most of those apps to my car via the ODB in WiFi. Now I can read some information but can't find the parameters you guys are discussing.
Do I have to just enter them in the command line interface option ?
Any help would be greatly appreciated
olding mirrors with a touch control
With this mod, mirrors will fold without having to be continually pressing the button on the remote.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Control Access 2
4 - Sub - Funk modus spiegelaklappung
5 - Change value By command via remote control look key
http://obdeleven.proboards.com/thread/17/coding-adaptations
Nice ! So I bought this car thinking I would get the Apple Carplay to put Waze on the screen and I can't cauz MB1, and now I learn that I can't mod my car because I have an iOS and the wrong ODB adapter ! Great
Research! Research! Research! I know it takes time but I always do that before buying and I must admit it does annoy my closest.Nice ! So I bought this car thinking I would get the Apple Carplay to put Waze on the screen and I can't cauz MB1, and now I learn that I can't mod my car because I have an iOS and the wrong ODB adapter ! Great
Thanks for your answer tho
