Hi all,
Just trawled through 33 pages but couldn’t establish is the headlight washer delay is a beta setting or included as standard now?
I saw some reference that beta was closed now for the Leon (facelift FR)...most of the options I want are already enabled on my spec fortunately but the constant headlight wash is frustrating already as need to fill bottle within a week at the moment so would like to order Carista and change this setting or is it something dealer can do? Wasn’t sure about all the debugging info for beta...does that provide any sensitive data or just car settings?
Thanks all
Geoff
Hi Geoff.
Can you just tip me off re this one? As you are a REGULAR user of fluid!!! Cheers Andy
After the recall and reset to factory I re enabled the one touch mirrors.
I also set the number of windscreen washers before headlamp washers from 5 to 15.
I left the delay as it was 500 ms [Microseconds! or was it 5000]
However testing yesterday the first use of the Wipe wash activates the Headlamp washers then not again [did not get to 15 ] Later on second drive it did it again first use wash wipe activated headlamp washers with no lights on]
1} Question is that normal even with headlights off the Headlamp washers activate.
[I thought it was AFTER 5 or 15 not starts then counts down and ONLY if they are ON.
2] What is the delay for and what should it be is it MS [microseconds]
If my system is now coded wrong how do I reset it or just revert to 5.
3] When using Carista with ignition on should I have left lights on AUTO or ON or just OFF
