new mk3 leon Fr 184 concerns
the stripler
Fighter pilot on Rails
Apr 8, 2014
87
Lanark, Scotland
Hi Guys
Picked up my Leon fr184 today. on drive home I was a little surprised by the noise in cabin.
The road noise is louder than any car I think ive ever driven??? is this normal.
tyres are Pirelli p7cinturato 6mm allround.
Could these possibly be the problem, or is this just how this car is.
Thanks for any advice.
gary
Wilkesy
255
29
Wait until rattles start on and around the dashboard. My 150 has this annoying rattle and haven’t the foggiest what it is and apparently Leon’s are notorious for rattles and loose parts
Hag
399
193
I have a 184 FR Hatch and I don’t find it overly loud on the road tbf. Mines a 15 plate
Mr Pig
2,628
910
With stiffer suspension and bigger alloys, differences between tyres are amplified. Noisier than an SE but shouldn't be that bad. I'm guessing tyres.
the stripler
Apr 8, 2014
87
Lanark, Scotland
Mines has the 17" alloys and 45 series tyres , so was expecting a quiet ride. Im guessing the pirellis are the issue here. Will change them sooner than later, just hope thats it...a lot of money wasted if not..
CupraGeezer
357
163
My guess would be that the tyres are the root cause of your problem although the Leon is known to lack insulation compared to the Golf. If you know anyone else who has a Leon, you could try asking for a ride in order to make a comparison.
Mr Pig
2,628
910
I can think of another possibility.
Your car has independent rear suspension. There are known issues that can cause the rear suspension to 'cup' the rear tyres. If that happens the tyres can be properly noisy, like a worn wheel bearing.
Run you hand over the inside edge of the rear tyres. If you can feel alternate lumps and dips as you go round the tyre, that's what your problem is. You might be able to see it as well.
the stripler
Apr 8, 2014
87
Lanark, Scotland
Whats the best way to add insulation,,, do any of the many advertised sound deadening matts work.
the stripler
Apr 8, 2014
87
Lanark, Scotland
If it has, is there any way to dial it out?
I was under the impression that the bigger brakes and better suspension was one of the reasons to go for the 184??
BoomerBoom
702
252
Just swap the rears over, side to side, to even the saw tooth wear and the noise out.
Mr Pig
2,628
910
That's right but more links means more to go wonky. If you swap the wheels/tyres for known good ones the noise should go away instantly if that's what the issue is. And like I said, you should be able to feel the wear on the tyres.
KXL
KXL
Dec 15, 2016
1,581
197
London, UK
Hi Guys
gary
Which car(s) did you have before? My only experiences are Seat Leon Mk3 (63 plate, 16 inch Bridgestone Turranza tyres) Seat Ibiza (66 plate, 17inch Bridgestone Potenza tyres) and Volvo V40 (68 plate 16in Michellin Primacy 4 tyres). Noisiest was Ibiza, quietest Volvo. Of couse if you had a BMW or Merc before, those are much quieter...
BigJase88
Jase
Apr 20, 2008
3,767
1,069
The leon’s are loud and quite unrefined, the pirelli’s are a good tyre so if they appear to look okay tread wise i would discount them as an issue if they were cheap chinese muck i would be looking at replacing them as cheap tyres are usually noisy
Jazzjames
160
68
Germany
I’m running 235/35 R19 Goodyear eagle F1 asymmetric tyres and can recommend them for their volume, or lack of it considering the wheel size. My winter set of 17” continental tyres are louder and hardly any more compliant than the 19s.
Good modern tyres make such a massive difference to a car’s road noise and manners. My mum’s Golf GTD was *transformed* when we changed from the factory fit Bridgestones to Michelin PS4 tyres.
Wilkesy
255
29
F1s or PS4s? once I have alloys sorted which tires would you recommend
Jazzjames
160
68
Germany
I have the goodyear eagle F1 asymmetric 3 tyres. When I get some new ones in a few weeks I’ll get a set of 5s, as they’re newer and even better apparently. They’re generally a bit cheaper than the Michelins but very closely matched so I’m happy to stay with them.
The Michelin PS4 (not PS4S) on the GTD are also great, you can’t go wrong with either.
Reactions: Wilkesy and Mr Pig
BillyCool
655
249
Leicestershire, UK
I've got the FR184 ST and don't feel it's that noisy. It originally came from the car supermarket with new cheap fronts and they were louder, harder and not confidence inspiring.
I now have RainSport 3's (last 12 months, 20,000 miles, 4mm left) and they have been fine. Do tend to agree that the Leon might not be as `smooth` as the Golf or A3 but that's why it's cheaper!
Can't help on any other reasons.
the stripler
Apr 8, 2014
87
Lanark, Scotland
I had the seat exeo st previously, great car and then more recently audi a4 avant, which was very quiet, however started getting a few alarm bells with the CVT gearbox so chopped it in back to a SEAT now.
Ive put my spare 17" wheels on from my TT with goodyear tyres on to try and it is a bit smoother, so thats a start.
And ive ordered some sound deadener for under the bonnet to hopefully reduce engine noise in cab.
Has anyone applied any of this stuff to the doors before? Is it worth the time and cost?
