Kaiju
Kaiju FR184
Jun 19, 2016
54
8
UK
Hi
I have a 2014 Leon and the front passenger window, when closing, made an awful bang within the door and the window dropped. When operating the window switch the motor can be heard working, but I believe the cables have snapped and the regulator needs replacing.
SEAT dealers are closed and I have no idea what to do. If I take door cards off, will I have access to the glass so I can lift it up and prop it with something so it remains closed and atleast I can use my car?
I am able to order the removal tools for the door panel and replacement clips, but don't want to waste my time if I can't then access the glass directly.
To freely lift the glass, would I need to disconnect anything else?
Any help appreciated thanks
Ps. Any idea what this would cost at a dsaler or a local garage?
Hi
Yes if you remove the door card then the circle rubber grommets at the top of the door and the big square rubber and speaker you will have access to all the nuts to remove the window and the regulator
Watch this video to remove the door cards https://forums.seatcupra.net/index.php?threads/how-to-soundproof-your-doors-mk3.446900/
You should then be able to push your window back up although you will need to support it somehow or it will fall back down.
If the motor is fine and you are ok with a bit of DIY knowledge you can probably fix this yourself.
Buy a window regulator from somewhere like autodoc.co.uk enter your reg number and search for one, they cost about £30 to £60.
This video shows how to remove the glass
which are held in by clips.
Then remove the regulator and replace, this vids for a Arona but the principal is the same
It will likely take a few hours, main dealer would probably charge around £3/400 maybe including part.
You could probably do it at home in about 2/3 hours for around £80 including the regulator and door clips as these sometimes break so always handy to have some spares.
Thanks for so much information
I will take a look once the tools arrive
I'll be sure to post here if I have anymore questions
So I managed to get it all off
Waiting for the regulator to be delivered but in the mean time so I can use my car, I managed to prop the window closed
Used a bit of wood and then used the existing regulator track holes as a way to bolt it in place. The wood is pressed right up against the clips which hold the window in place.
Great improvisation with the wood.
Once you have your regulator it should be all good.
May need to get an extra pair of hands to help you lower and raise the window and hold it at the correct height then you can put the trim removal tool into the clips holding the window from the top like the video to unclip and remove the glass.
