I'd be inclined to try it without the spacer so that it's getting a more accurate reading although it's likely to push the emissions up a bit.Quick question, since getting my sport cat fitted my O2 sensor has still got the spacer in, no EML. Is it worth taking it out or will it not affect any fuelling?
Awesome thanks Thai. Been debating whether it’s worth the effort, havnt looked but I might need to extend the wires.I'd be inclined to try it without the spacer so that it's getting a more accurate reading although it's likely to push the emissions up a bit.
If the EML light stays off then see how it goes at MOT time.
Ordered a full tubular front subframe kit for mine...race geometry here I come
And carbon bonnet and bootlid.
Anyone want to buy a full subframe and bottom arm set up all with new superpro buses including castor adjusting bushes. Have done under 500 miles on the car.pm me![]()
Sent from my SM-G988B using Tapatalk
Today i replaced coils for 4x Beru coils since one was dead after a heavy rain so i replaced all and 4x bosch copper with 4 electrodes (standard ones)
Now car steering wheel is calm and steady on idle, it was kinda shaking before the spark plug change. Old plugs were ngk iridium but they were totalky worn out
The worst of the worst happened, unthinkable, unimaginable disaster...
I LOST A JACKING POINT COVER![]()
My heroI have 4 going spare just breaking a Leon cupra tdi
noooooooooooooooooo- How very careless of you - You are on detention - Report to the headmistress at 3pm sharp !!
noooooooooooooooooo
