Try this:Can you disable auto rear wipe when selecting reverse through obd11? Had a quick look through the control modules this morning, but nothing jumped out!
For some reason it doesn’t work on my 2017 FR, despite me being able to do it manually and change all the colours and add new ones. The app to add 10 or 30 colours just won’t work, says my vehicle isn’t compatible.Just noticed that obdeleven has the option for 30 colours in the ambient lighting menu which applied fine to my 2018 Leon. I was under the impression that I actually needed a newer one for this to work?
Not complaining obviously, just didn't realise it was possible. If anyone else was wanting this, might be worth looking at.
I dont need an extension. The cable i have it long enough. Just asking if there's some space behind centre console to fish it through there??Buy an obd extension cable.
Would love it if someone could figure that one out. Even when you move it over to the VC, the speed is on the 8" screen (if in a slightly better position to see on the right).Has anyone displayed the sat nav speed limits on the cockpit display?
I know if you have traffic sign recognition the speed limit is displayed in the cockpit. However if you don't have traffic sign recognition can you display the speed limit for the map data?
You could try looking here. Mind you this is for the pre-facelift cars.
Full beam on our cars is both dipped and high beam at the same time. When you hit full beam with lights on, with the LED's it adds high beam and also raises the headlights.I'm hoping to make 2 modifications to my LED headlights if they're possible.
1. Unlock lights, not coming home lights at all but I'm sure I have seen someplace that when you unlock your car that your DRLs can flash with your indicators when you unlock the car? If so, has somebody a guide to code that on OBDEleven or similar?
2. When I'm driving on DRL and have to flash somebody, let them cross, say hello and pull back on the stalk then both my dipped and full beam flash. Surely it should only be the full beam that flashes, like any other car. Is there a way to code this?
Thanks in advance
Just seen this....dont know if you got an answer, but having just done it myself the answer is yes...you can do it.I dont need an extension. The cable i have it long enough. Just asking if there's some space behind centre console to fish it through there??
Thanks, managed to do it in the end. Took 4 hours but worth it!!Just seen this....dont know if you got an answer, but having just done it myself the answer is yes...you can do it.
I just JB4'd my 2.0 tsi 190 (MY19)
I did the alarm cherp but it didn't work, any ideas why?
Sent from my SM-N770F using Tapatalk
