K8VXT
Hi Guys:wave:
I am having some problems with a rough misfire sort of idle (Seat Cupra 280 DSG 2014)
So first thing I did was ran codes on the car, 2 errors were stores and but they did not chuck an EML light.
- P006800 MAP / MAF - Throttle Position Correlation
- P227900 Passive/Abiogenesis Intake Air System Leak
After running these I went with the most obvious part to change, the PCV.
Replaced that and however, I am still getting a rough idle.
At this point I'm open to what people suggest, anyone experienced this or know what to do next.?
Thanks,
Kavit
Does your engine wobble on tickova , my 290 does this but when i took it in they said nothings up
Sent from my MRD-LX1 using Tapatalk
Yeah a little with my 280 tbh, weird.
This is issue I'm having is on idle and the engines warm.
No jump in revs just a rough wobble.
Reactions: Cuprabenwytm
Mines exactly the same revs dont move but the engine wobbles about, im. Gunna take it back. Now av seen your diagnostics
Reactions: K8VXT
Got the same issue on my 290, misfire on warm idle only, did you get yours fixed?
Hi Guys:wave:
Thanks,
Kavit
View attachment 19375View attachment 19377
Unfortunately still a problem, they said to wait until it gives a EML or its obvious where the leak is (trying to find somewhere that does a smoke test)
My suggestion would be for you to plug in an OBD see if there is any stored errors.
