Rough/"Misfire" Idle
K8VXT
Hi Guys:wave:
I am having some problems with a rough misfire sort of idle (Seat Cupra 280 DSG 2014)
So first thing I did was ran codes on the car, 2 errors were stores and but they did not chuck an EML light.
- P006800 MAP / MAF - Throttle Position Correlation
- P227900 Passive/Abiogenesis Intake Air System Leak
After running these I went with the most obvious part to change, the PCV.
Replaced that and however, I am still getting a rough idle.
At this point I'm open to what people suggest, anyone experienced this or know what to do next.?
Thanks,
Kavit
Cuprabenwytm
323
110
Does your engine wobble on tickova , my 290 does this but when i took it in they said nothings up
Sent from my MRD-LX1 using Tapatalk
K8VXT
Yeah a little with my 280 tbh, weird.
This is issue I'm having is on idle and the engines warm.
No jump in revs just a rough wobble.
Reactions: Cuprabenwytm
Cuprabenwytm
323
110
Mines exactly the same revs dont move but the engine wobbles about, im. Gunna take it back. Now av seen your diagnostics
Reactions: K8VXT
Feb 6, 2019
Got the same issue on my 290, misfire on warm idle only, did you get yours fixed?
Hi Guys:wave:
Thanks,
Kavit
View attachment 19375 View attachment 19377
K8VXT
Unfortunately still a problem, they said to wait until it gives a EML or its obvious where the leak is (trying to find somewhere that does a smoke test)
My suggestion would be for you to plug in an OBD see if there is any stored errors.
