Getting the nut off the top is all I really need - I've been spraying it with penetrating lube since Sunday. The driver's side came off yesterday, but that was already spinning and just needed a jack underneath it. I'm sure it'll loosen up if I keep spraying it.You could try the two hammer trick to get the ball joint out hit both sides off the hub at the same time
Oh the tales most people here could tell.
Like the garage who replaced a gearbox for me under warranty, collected car, drove it, went for 5th, wouldn’t have it, tried again, nope, turns out they’d fitted a 4 speed box so I had to pay extra for the 5 speed it should have had.
Or the garage that did work on the front left suspension but had neglected to tighten up the tie rod end which was fun to find out at speed as the car decided to change lanes of its own accord.
Or the garage who did an engine swap after the original snapped two cams in quick succession. Said “Here’s your car, all fixed”, took it away, within a few days the oil light came on on a long corner, pulled over n stopped, engine hot seized on the spot. Their response? We told you to bring it in (they hadn’t)
Or the garage who said my sump was cracked and leaking on the Leon which, along with a couple of other bits for MoT, would’ve been £700+. The ‘cracked n leaking’ sump is still on the car btw n has never dropped any oil or been mentioned on any MoT since.
But have found a garage who now does my MoTs and they’re pretty good. I just do everything else.
Somebody nicked my osf skirt cover, now making another one. Bet the bitch was gutted when he saw I made that one also hahaha.![]()
Sent from my M2007J20CG using Tapatalk
We bought a new jeep last year. Well two years old. 25k miles. Clutch was slipping. They replaced it under warranty, pinched the loom when putting the subframe back so had it again another week. Tried to put o2 and lambda the wrong way round then didn’t tighten the oil lines on the turbo so it was dripping onto the mani, I told the guy in keep what was wrong after they’d sent my wife away twice saying it was all in her head. I had to take it too them in pieces to show them.
All sorted after that
Time for a cuppa tea.![]()
**** you, you ******* piece of ****. And the horse you rode in on.
lol my solution to draining the catch can without ripping my hands to pieces
No pal just a plastic clipboard, bloody hot water and some bending cuttingThat’s cool.
Did you make a mould for it?
Badger5 Custom Map + TIP,
Alternated between spraying it with penetrant and drilling it out in the end. Thought I'd be able to just run a 9mm drillbit down the middle, but had no access really so just ended up ragging the drill from every angle, convinced I was going to end up with a stump flush with the subframe. In the end, I was tapping the chisel in from the left to try and pull the dogbone off the snapped bolt, and I got that creaking sound where you know something's happening, and then it just dropped off. It totally caught me by surprise. Vice grips on the leftover bolt, but I could have just spun it off with my fingers. You can see the bolt was properly caked.Lolfeels good doesn’t it when you get the parts off that’s been a pain in the ass
I thought you had done that to keep the big turbo off the breaker. Should go really well with the hybrid setup still.Spent the entire friggin day back tracking on some of the work I'd already carried out and created a big space behind the head...
Seriously that was bloody painful!
The plan for tomorrow is to get it all back together with the AET380 turbo, port matched Chinafold & new Badger5 V.2.2 80mm TIP.
