Mk1 Leon Cupra TDI Track Daily
MoToJoJo
784
600
Northants
My last project didn't quite go to plan, a race car was a fun idea but the car in question probably wasn't the best choice. So I have my 'snow car' (usually ride a bike but snow is... interesting).
It was pretty standard (don't look at the exhaust) and I was thinking about getting shot of it, picking up something newer on PCP.
But it's now destined for upgrades because I figure I can play around with aero etc and if it breaks I can pick up another and swap the parts over. Also I have spares from the TDI I scrapped so I can test bits out if needs be.
Reactions: Syphon
MoToJoJo
784
600
Northants
Mods so far
Brakes
Phase 1
312mm front calipers
Standard discs
EBC Bluestuff pads
256mm rear brake calipers
Standard discs and pads
Hel braided lines
Suspension
Phase 1
Koni FSDs
H&R springs
Cupra R top mounts
Audi TT rear LCA bushes
Cupra R beam bushes
Random uoper strut brace
Audi TT lower strut brace
Phase 2
Cast front arms
Cookbots wishbone inserts
Superpro wishbone bushes with offset rears for increased castor
Audi TT hubs (fully rebuilt)
Audi TT V6 steering rack
Powerflex Black Series steering rack bush
KW V3 coilover suspension
H&R 25mm adjustable front ARB
H&R 25mm rear ARB
Cupra R rear beam bushes
Cupra R top mounts
Powerflex dog bone mount
Random upper strut brace
Vibratechnics street density engine and gearbox mounts
Engine
Miltek cat back exhaust
Darkside Developments silicone coolant hoses
Odyssey Extreme PC950 battery
Transmission
Forge front/rear short shift kit
Forge side/side short shift kit
42Draft solid shifter bracket bushings
Darkside Developments solid cable end bushings
Gear lever relocated to on top of transmission tunnel
Wheels/Tyres
Standard Cupra Starfish wheels
Goodyear Asymmetric 5s
RacingLine stud conversion
H&R 8mm spacers all round (so I can fit the caps over the wheels and maintain a stock look)
Interior
OMP First R seat (driver)
OMP Design 2 seat (passenger)
TRS 4 point harness
Stripped carpets and roof lining
MoToJoJo
784
600
Northants
Thought I'd get a baseline figure for the weight of the car.
This is every fluid full, full leather electric seats etc, no driver.
Not bad balance but would like to get that weight down
Reactions: Manic172 and Syphon
chrismc
25
16
Highworth, Wiltshire
Oof- quite some weight!
What are the standard ARB diameters? Shouldn’t the front be somewhat thinner than the rear to dial out any inherent understeer?
I’m sure that was the case from my tweaked mk2 Golf days
MoToJoJo
784
600
Northants
Yeah, it's not the lightest but will be getting stuff on the scales soon and see where weight can be offloaded/moved around.
Stock ARB is 23mm up front with no rear ARB so 25mm front and back makes a difference, it feels very planted in a neutral way, haven't really pushed it yet though
Reactions: chrismc
MoToJoJo
784
600
Northants
First change was the shifter
Forge short shift kit (both front/rear n side)
Darkside solid cable end bushings
A recon'd bracket fitted with 42Draft solid bushings
The test drive showed the downside which is that it's a very notchy feeling when shifting (it's set to almost 40% reduction in both planes).
On the upside it's extremely direct which means heel n toe has gone from being ill advised to an absolute joy, it really makes it worthwhile.
MoToJoJo
784
600
Northants
Next (and possibly the most controversial) bit is an ITG Maxogen induction kit
It's eye wateringly expensive (in my defence it was advertised as being made of carbon fibre on Awesome) and I know some will question its usefulness on a diesel but there's method to the madness, just have to wait for future updates to see why I went with it
MoToJoJo
784
600
Northants
Genuinely can't believe how different changing gears is now thanks to the quickshift and now this
Mounting the lever higher has made the driving ergonomics so much better
MoToJoJo
784
600
Northants
Been a while so I thought I'd comment on the suspension setup before I say about the mods done.
Had the opportunity to take the car out on track (Silverstone National circuit) during Trax, this being its first in anger test since the suspension work. Set the shocks to full stiff at the front and not quite so much on the back, can't remember what the front ARB is set at.
So, car is in need of a power increase from a remap (fairly sure there's a boost leak as well) but the suspension is awesome.
Everything is much better, less body roll, better response to bumps. I usually run on the kerbs which previously meant a lot of noise and rattling inside the fully insulated cabin, but barely noticed them with the harder suspension and stripped out interior.
The thing that really impressed was throwing it through Copse at speed (3rd at high revs I think), back end leaning out as opposed to the understeer expected, and then being able to modulate that with the throttle. Wasn't expecting that and very happy.
Won't be doing much more to handling but an LSD, solid driveline mounts and some stickier tyres are on the wishlist.
Reactions: 300bhpdaily
300bhpdaily
1,246
568
Just goes to show much handling mods make a difference on track. How far are you from thruxton out of interest? Next time we all book on I’ll let you know see if your available.
MoToJoJo
784
600
Northants
I'm about 2½ hours from Thruxton so it's doable. Appreciate the consideration 👍 I might actually remember a tow hook next time
MoToJoJo
784
600
Northants
So it's winter again and that means it's time for some work on the Leon. Today was a relatively easy day, playing with things on the passenger side
Started out like this
Stripped things out and thought "Let's give it a wipe down"
That's better
MoToJoJo
784
600
Northants
First job was swapping the gearbox mount, don't think the OEM was in bad shape but hey, upgrade
Gone for the Vibratechnics Street Density as I thought Track would be a little bit much.
Was surprised by the weight difference
Fitment was pretty easy really and it looks pretty good too
