Not sure how thats going to work the traction control can only be turned off as far as i am aware in vcds. Would love that option in my 1.8 fr also. Let us know how you get on
Hello,Hello everybody. HELP!
I have just made the modification on my Seat Leon FR 1.8 (2017) with a professional working for Seat.
We can't find the solution. We followed the connection precisely. The button works but when I press it is combined with the Start & Stop. So that activates the Start & Stop. Do you have a solution? What did we miss?
How exactly did you do it? Do you have a specific diagram or tips? Do I need a coding to activate it?
Thank you very much in advance for helping meTHANKS THANKS
I don’t think that you use the right scheme. As you can see in the earlier post i add the scheme. The button should be connected to abs connector near engine. For leon exist two different connections. You need check your abs in some cars it’s should ve connected to pin 3 and in another to pin 38 as i remember.He is a mechanic friend who worked outside of these working hours. Here is the diagram he made and the result activates or deactivates the Start&Stop ... Do you think you can help me? Is it really without the need for coding? Thank you in advance ...
View attachment 24095View attachment 24096
the guide qute same for golf leon and octavia only the one thing need to be understand that the connector of ABS can be different
if you have the same ABS unit it will be work fine for another unit connection have some differentit seems to work fine https://www.clubseatleon.net/viewtopic.php?f=40&t=108546&start=105
Did your friend achieved the retrofit? was it the pin 39 on his 2017 model?if you have the same ABS unit it will be work fine for another unit connection have some different
