I have a 200 cell sports cat on mine, it has passed its last 2 mots with it, but they are a pain, need too be nice an hot before going in. Mine needed a couple attempts to find the sweet spot but my mot bloke is sound and got it through, most can't be bothered to do it he said. Good luckJust a trip to the hand car wash after work.
But tomorrow i will mostly be doing an emissions test on my car under mot conditions to see how the new 200 cell sports cat holds up.
Will report back.
I did the same on my old FR TDI.Spent a couple of hours cleaning the engine bay and modifying my engine cover - ever since fitting the strut brace the cover never fitted
So measured and marked before slicing a section off
Sanded & smoothed the edges, have it a good clean then painted the I with red enamel paint (3 coats)
Fits and looks just right
I've used the 3M headlight restoration kits several times with decent results.What kit did you use on the headlamps?
Ive got a slightly frosty one.
Oh, a new headlamp it is then.So cleaned with Bilt Hamber Surfex HD, polished with CarPro Ceriglass + pad on Das6 polisher x 3 times, cleaned again then 3 layers of Meguiars Ultimate Paste Wax and buffed off with MF cloth.
problem with the cover the dam sound damping foam disintegrates due to ageSpent a couple of hours cleaning the engine bay and modifying my engine cover - ever since fitting the strut brace the cover never fitted
when contracting at vitafoam i wanted the same fire poof foam but none was there at time, wanted a rated temp foam as i did not want to chance itYep, I ripped mine off ages ago.
We use insulation foam at work (high temp stuff) so gonna try a bit of that and see if it’s ok
