Alexis27
2,213
543
Manchester
Yeh, hasnt got the bearing drone at speeds and doesnt have the cracking noise you get from a cv. No play in the bearing.
Its a wierd one.
Its fine when i 1st jump in the car. Starts making the noise once ive done a few miles but i always get the noise on roundabouts. Like a scraping noise can be heard from inside the car.
Havnt noticed anyone look at the car as ive driven past em wondering what the noise is so not sure how loud it is outside.
Its a definate head scratcher.
A proper VAG specialist garage is useful for stuff like this.
iammooks
1,829
1,232
Yeah - I was just thinking in terms of something being off centre or not flush. It's a sound I've heard on bikes where things like bottom brackets or headsets aren't quite flush, and so they bind at various points when they turn, but given there's not much to go wrong in terms of car wheel bearing installation, it's less likely. It's not a sound I've ever heard on a car before though.
MoToJoJo
860
704
Northants
Everything put back together, test drive done, so just chasing issues to do.
Might fit the sideskirt extensions tomorrow cuz the splitter looks alright
iammooks
1,829
1,232
View attachment 29049 View attachment 29050
That engine's done several thousand rotations now - if it hasn't blown up yet, I think you're OK. My only issue was a boost pipe clip not on properly. When you suddenly lose all power and the car is pogoing down the road, you think the worst, especially when you've just changed your cambelt. Turned out the hose had just popped off.
That splitter looks really nice - is it secure?
Rich.T
1,589
930
Going to get this sorted then possibly put the car up for sale.
Got a letter through the door today from my bank letting me know i can borrow at a decent rate.
So may get something more modern now that i dont have access to a workshop.
Tbh, ive been looking at Audi A1s for a while.
MoToJoJo
860
704
Northants
Believe it or not, one of the issues is the boost pipe popping off. It's the drivers side intercooler one, dunno why it's such a pain 🤣
Spoiler's pretty secure, got 14 bolts in it. Wouldn't stand on it or anything but I'm not worried about it falling off
Reactions: iammooks
MoToJoJo
860
704
Northants
I understand that feeling. Sometimes the hassle outweighs the fun.
The A1s look pretty cool
Reactions: iammooks and Rich.T
iammooks
1,829
1,232
That's exactly the pipe that popped off when I did it. Must be a rite of passage or something.
It's a pipe I replaced recently, so I made damned sure it was on properly. It's not so bad if you just need to get it onto the pancake pipe again, but if you need to do the intercooler side as well, the only way I could really do it properly was by taking the foglight and grill out.
I might have to have a think about a splitter - maybe when I respray my front bumper.
Which reminds me - my nearside fog isn't working. It might be that I didn't plug it back in when I put a new horn in, but if I do need a new bulb, does anyone know which it is? I'm seeing H3 when I look online.
Rich.T
1,589
930
You maybe on to something there.
Ran the car for 10 miles or so to get it squeaking then jacked it up.
Slight play in the bearing.
Went to the garage i use and its going in Tuesday.
Sead theyre busy but will try n get it done.
If they dont do it, I'll be booking it in for later in the month.
See if that sorts it.
Reactions: iammooks
Alexis27
2,213
543
Manchester
Today I was an idiot and believed a part from Euro Car Parts would fit, even though I gave them my reg number and they said it was definitely the right one. Namely handbrake cables.
Twats.
iammooks
1,829
1,232
Twats.
Euros are so hit and miss. The trouble is that you don't need to know anything about cars to work there. Last year they sold me an OSR caliper in a NSR box and didn't seem at all fussed when I pointed that out to them.
Kind of like Halfords really.
It's lovely when you get someone who knows what they're talking about though.
Reactions: Alexis27
MoToJoJo
860
704
Northants
Fixed the boost hose (hadn't properly seated the spring clip) and took it for a longer run. Seems to be heating up faster than before but it's not overheating. No leaks spotted either. Long running EML has yet to switch back on so that's good.
Just a couple of things to do and it should be ready for MoT
Reactions: Rich.T
Connor H
1,032
516
Essex
changed my clutch master cylinder this weekend because im losing pressure in the clutch pedal and struggling to change gear, annoying bc new dmf csc and clutch bout 6 mo ago. seems not as hard to shift once its warmed up..
bled a few times still got the same issue, pump the clutch and get somewhat better and can just about shift gear. No outward leaks...gonna replace all the seals in the clutch pipe connectors and the whole bleeder block and see what happens.
Rich.T
1,589
930
VW bond some parts of their body kits/spoilers on.
Very strong stuff.
Maybe go to your local dealers and see how much they charge.
