I’ve noticed this on my 18 plate Leon too. It wasn’t there and then it was. It looks like someone has to prise it off. But that is not the case.
The car i have now was like that dealer replaced unit before i picked it up
They said the same thing someone was trying to remove the panel.
I'm sure it was around £500 to buy the part.
Hot weather we've recently had has caused cracking to get worse
  • Wow
Reactions: H Rafiq
Update on this one. Seat replaced it without any questions on my last service. Looks like new again. Didn't admit known fault but I had all the pictures of it getting progressively worse over the last 12 months and they replaced under warranty :)
Reactions: JSR
Bumping an old thread, I'm replacing the control panel with one i got from ebay, will it throw up any errors?
I saw on YT someone had the airbag light come on which then had to be deleted on vcds.
Anyone?
I'm not sure, but I think as long as you disconnect the battery it should be OK, you will get a lot of warning/error lights after but they should go off after a bit of driving and turning lock to lock.
Ok, thanks mate!
Reactions: Walone
