I've got a 2014 184 CUPA engine on 152,000 miles. It's always used some oil and needed regular top ups (unlike my
Mk1 Leon with PD engine).
Some of my observations:
- The oil level on the dipstick and trigger point for the low oil level light are pretty close. I can have 3/4 on the dipstick and suddenly it can be at a 1/4 and the light comes on. It just seems to be a bit sensitive and I now actaully top it up to full and it definitely reduces the low oil warnings. Only topping it up to 3/4 never seems to be enough.
- I had my cam cover replaced last year as it was the source of an oil leak. They are VAG plastic/chocolate and are prone to heat fatigue and can crack and leak oil. It was leaking down the back of the block so hard to see/trace to start with.
- I had the oil cooler/filter housing replaced a week ago due to excessive oil temp. The garage said that the seals were also failing and it had also developed an oil leak down the front of the block. The main filter housing body is also made from VAG brittle-sh!te and prone to failure.
My conclusion is that the car does use some oil, no doubt. I don't think it is excessive and with the cam cover and oil cooler both having oil leaks, I'm pretty sure that some of the long term oil "use" could just be oil leaks. I'm going to see how it goes for the next few thousand miles and whether the consumption has improved.
As long as you do not have milky oil or any reason to suspect head gasket etc or other oil loss and the car runs okay, I wouldn't worry to much. I use 5W-30 507.00 oil in mine and also change oil & filter every 5,000 miles. The car seems to like it and I plan to run it until it fails, so trying my best to look after it. If you think your consumption is super excessive, then have a good look around the engine for any signs of oil leaks.
