Sep 22, 2023
10
sweden
I am in the process of upgrading from a 6F0035871A to the nav unit 5QA035858B and the 6F0919605A display.
So from this... Untitled.jpg to this.. Screenshot 2023-09-26 at 19.43.08.pngand this Screenshot 2023-09-26 at 19.39.56.png
I already got the pink-to-blue LVDS cable, but can't figure out what else I need. Can anyone tell me what additional cables I will need and where I can find them? Like what are the blue and black connections on the back of the nav unit?
Very thankful for any kind of help or advice anyone is willing to offer.
muito, muito obrigado para the pics! so are these the right cables?...
1. https://www.aliexpress.com/item/4000187573385.html?pdp_npi=3@dis!SEK!SEK 260.30!SEK 247.33!!!!!@2101c6d716958442079681687d49d6!10000000699704752!sh01!SE!784870402&spm=a2g0o.store_pc_home.productList_578470514.subject_5#nav-review
do I need the 25cm or 60cm?
2. https://www.aliexpress.com/item/32325381431.html
do I really need a new cruise control cable?!
3. https://www.aliexpress.com/item/1005005184707351.html
do I really need this one? the double white connection looks the same as the original unit that I am replacing so it should already be there when I pull it out?
I already bought this one..
https://www.aliexpress.com/item/400...o.order_list.order_list_main.5.68db1802Yq1SnD
On a previous post you wrote that 2 new cables are required when doing this upgrade. If I buy all that is so far recommended I will have 4 new cables. And I still don't know what the blue and the black connections on the back are for (maybe one is a navigation antenna and the other?). If I figure out what those are then I will have 6 new cables.
Olá,
sorry nº2 its a Wrong cable is similar to what is needed, It's the cable that I said is very difficult to acquire.
Nº2 you need 60cm the plug is in the radio hole and the cable is short and you have to take the plug to the glove compartment to connect to the module that will be installed there
Nº3 If your current radio only has one white socket (and mine only had 1) you need that cable to divide it into 2. If you already have 2, you don't need it.
Reactions: timmothee
I bought everything needed for this project for my Ibiza and then switched to a León before I found time to do attempt the switch. So, i have everything here that I don't need anymore, it is ready to post to someone if they give me a reasonable offer for it.
