Fitted the charger today. Working perfectly. For now I cut the holes in the mat that I had. Waiting for shipping the new mat to my dealership. It may take 4 more weeks.
Thanks @Remis for a very comprehensive tutorial.
Reactions: krmzl and Remis
Does the facelift Cupra Formentor 2025 have a cooling feature in the wireless charging pad? Mine seems to still heat up regardless when charging and i cant seem to locate any vent openings in the cooling pad. I am sure i heard in a review that it did have this feature but i could be wrong.
Take a picture of how your pad looks. When I tested the facelifted VZ and had the loaner Service 1.5 version, it used the same cooled charger. Even with cooling, the phone still warms up when charging wirelessly, but not as much as it does on a pad without cooling and it charges faster.
Hello ,
I know this is an old thread, but I am looking at a cooled wireless charger for my 2022 Leon MK4 as the current one gets really hot and doesn't charge my phone properly.
Am I correct in thinking I need these parts from a dealer?
6VA035502 for the charger plate with fan
5FB863330B 4PK for the vented rubber mat.
Many thanks.
Hello ,
Many thanks.
Hello,
Yes you are correct. Just bear in mind that if seat/cupra dealer won’t be able to offer 6VA035502 part you can check Skoda dealer (i took from broken newer model Skoda Scala L&K).
Reactions: Kfav82
Hello ,
Many thanks.
or check ebay there is one in uk :)
VOLKSWAGEN POLO MK6 2025 WIRELESS CHARGER MODULE UNIT 6VA035502
Thank you, I did watch that item on ebay earlier so will look at purchasing. Do you know how much the part was new from a dealer when you were looking to purchase? Just wondering whether to buy a used part or new.
Just a note to say thanks for the info here. I have fitted 6VA035502 (£50 off a 2025 Polo on Ebay) and it works great. But the issue is the mat 5FB863330B 4PK. I ordered it as it was a non stock item and it appears to be for a LHD only as the rear upper section doesn't fit. Do you happen to know what the RHD part number of the mat would be?
The image below shows the pointed section is on the opposite side on the new mat.
It's on the other side on yours...
Update: The correct part number for the RHD version rubber vented mat is 5FC863330B 4PK.
