so is the 9.4% actually -9.4%? minus fuel trims means rich, positive means lean. does it have standard auq injectors in it? it be doubtfull its a bent rod if the car feels fine for a while on a new maf but then starts tailing off again over a week or two.
when i got my auq stage 2 i noticed that it was overfueling upto and around -12% ltft, so i bought a mpps cable, downloaded the map and edited the krkte to scale the bam injectors that id installed back down so that it was closer to 0.0%, it made a big difference in how the car drove, was much more responsive on the throttle since the ecu wasnt having to pull as much fuel back. although this doesnt sound like your problem i dont think.
Honestly i cant remember, i measured it and checked against the thresholds and it was fine so moved on. I will have another glance at them soon once its used to the new maf.
yeah normal injectors. I know there is 100% something wrong with it because ive been in two other 1.8t's at the same power level. if I cant figure out im not bothering with a 1.8t specialist 3 hours away, ill just look for another cheap cupra and part this one out and be done.
="Connor H, post: 5103196, member: 123323"]
Yeah mate completely fed up, so this is very much appreciated.
Just ran the logs for you now buddy, took her from 1.5k to 5k rpm on multiple pulls, the VVT stays firmly off at all times. Load was over 100% on multiple occasions and nothing. Seems it only functions at cold start and that's it.
Happy to run any other logs you need.
Reactions: Connor H
Damn, when you're right you're right! Thank you so much for proving me wrong. That was the last thing i could find, i am at a total loss now. Guess i better start saving up for another leon. Not many around anymore either :(
Reactions: mty12345
Tbh i was realy hoping i was wrong for your sake, but at least we know for sure now.
I'm guessing you've probably already tried it, but I couldn't see it mentioned, have you replaced the fuel filter?
Me too mate. Ive thrown money at the issue for a few years, I cant think of any other reasons why the airflow would be reduced. Feel like setting it on fire now. Really thought id get to the bottom of it... People probably think im just talking up a non-issue!
fuel filter has been replaced in my ownership.
Ill probably do another round of logs, do the obvious, fuelling, timing etc. Might check the exhaust doesnt have a blockage. Other than that, maybe my clutch could be at fault at a reach... but its rated for fair bit more power than i have, and i dont think i have the spirit to take the gearbox off again lol. Worse thing is if i sent to say R tech or badger 5, itd cost me thousands. Totally not worth it!
id be thinking about it being the ecu if youve changed and checked everything else, what did tuning technics say about it? hes usually pretty good at this stuff in any videos ive watched of his
i know hes great and very clever, but he simply didnt care and just tuned around it, even though he agreed it felt off. a few months later i was left with a car reading 150gs again.
could try a different ecu i suppose, will need to source a cheap immo off one. Pretty reluctant to spend any more money at this point
This is rough for you mate, you've given it everything you can & it's still being a pain in the arse. I really hope the answer is lurking around the corner🤞
Reactions: Connor H
if i was closer id let you try my ecu on it see if it made a difference, ive got another ecu there with a stage 1 on it but its got immo on for my car.
its got to be maf or or ecu problem youd think though if a new maf works for a while then its tapers back down to the 150g/s after a while and the only cure is a new maf again, must be wiring or something internal to the ecu causing it.
I keep flip flopping between it being an ecu problem or a mechanical problem. Im getting to the very end of the list of physical components it could be by now , really i want to check my rods are all good. horror stories of inaccurate test kits putting me off buying one for a one time use though
I even in a moment of anger today unbolted the exhaust and ripped it through the gears and obviously no different, still laggy in the powerband. just ringing ears lol.
I cant imagine another MAF will cure it, while it does restore overall power for a bit, its still got this 1-2 second delay where the revs slowly build up.
Failing it being rods...- clutch, flywheel, those are the last mechanical things i can think of. And i have replaced both a 4 years ago!
what about the throttle pedal? you can log its position and voltages in vcds, the pedal has 2 potentiometers that could be laggy or never reaching full throttle.
i got my compression tester from amazon, daygun or something, cheap and nasty for £25, it seemed to work fine, all cylinders were within a couple psi of each other.
I actually did check my pedal position and it was reading fine, flat was 100% or nearly. I logged my TB position during WOT too. i really have been to every corner possible with this sh*te lol.
I do appreciate the suggestions though, so if you have anymore keep them coming and ill keep checking. Ive spent enough money and time, i might as well give it some more thought.
