Can you code in full led flash?
After paying for the full app I could code this in so fog lights flash with full beam flash - they don't come on when full beam on all the time. Haven't really looked at the other coding options yet, but worth what I paid, plus I got a discount on the app through play store!
Tried this today with my son's 2017 Leon SC 1.4 150 FR Tech and enabled needle sweep, unhelpfully called 'Test pointers at engine start', and also visual Park Pilot with only rear sensors using the long coding...
1 - Module 76 - Assisted parking
2 - Extended coding (Bytes Mode)
3 - Byte 2 - (Activate Bit 0)
The sensors now display visually but the actual beeping no longer accompanies them, is this right or have I missed something?
Secondly, how would I do something like this using the app...
1 - Module 09 - Electronic control unit - Code (31347)
2 - Adaptation
3 - Spiegelverstellung
4 - Funk spiegelaklappung modus - (Change value to By look command via remote control key)
...as going to Module 09 in the menu only offers changing Bytes
Hi all thought id post up a bargain.
On the play store this app can perform long coding and adaptations to all the seat audi vw range and cost like 3 quid.
So far i have done
Needle sweep
Engine torque limitation
Drl off with switch in off position
Drl dim with indicators.
Esc options esc off and esc sport
The weekend i am installing rain light humidty sensor for auto light and wipers.
The app is really good and works with elm 327 thought id let yall know
Where is the option for the needle sweep in car scanner I have the full paid version
2 - Adaptation
Where did you get this information? I mean to know how to code park assist? Is there a long coding guide or something? I'm looking to get rear LEDs to come on as part of DRL. Thanks
from post 22 above "enabled needle sweep, unhelpfully called 'Test pointers at engine start'," I believe in dashboard settings
Hi, came across this while searching for an OBD eleven tool. Looking at adding android auto but I would need to code it when installing. Would this do the job? Thanks
Android Auto is a FEC (Function Enabling Code) controlled feature and your infotainment unit needs to be patched with modified firmware to allow using a cracked FEC. This can't be done by Car Scanner or OBD11, you'd need a retrofitter's services, or to buy licensed Full Link activation from a dealer.
No, for that you either need a professional or try DIY *at your own risk* with sdcard patches from mibsolution.one. Note - these patches are specific to certain hardware and firmware so proceed with caution - but done right I know it works (because I did it on my car).
Where car scanner pro did come in useful was in adding back in some settings that were lost when I changed my multimedia unit for one from a different car with a different audio/speaker setup. Car scanner pro let me load up the correct Seat Sound settings for my car - so it is very definitely worth buying at the price it is (or was!) - also scans my alfa and many other cars.. absolute bargain compared to OBD11 which I also had for a while.
Hi,
Own Seat Tarraco 1.5 MY2021 and Carscanner pro. Would like to turn off/deactivate fuel flap autolock after moving a car but can't find this option/app in adaptations. Bytes in Long Coding [guess module 09 central electric] are undescribed so it's hard to change anything. Learned from the web that this function name in OBD eleven is "geschwindigkeitsabhaengige tankdeckelverriegelung" and is located i module 09 adaptations. Anyone succeded in deactivating fuel flap autolock via Carscanner pro?
Thanks a lot in advance for any hints and advices.
Hi,
Following is the search results from Google. Not sure it is entirely correct but worth checking I believe.
The equivalent of the OBDeleven Control Unit 09 adaptation "geschwindigkeitsabhaengige tankdeckelverriegelung" in Car Scanner ELM OBD2 Pro is found under the text option "Disable automatic locking of the fuel door while driving" (or "Fuel Flap Lock" / "Speed-dependent fuel filler flap locking" depending on your specific vehicle profile).
How to Find and Code It in Car Scanner Pro
Because Car Scanner maps VAG adaptation channels to user-friendly text descriptions, you will not find the raw German name. Instead, follow these steps to alter it:
Prerequisites: Turn your vehicle ignition ON and make sure you open your vehicle's hood (bonnet). Modern VAG cars (MQB/MQB Evo platforms) will block diagnostic adaptation writes if the hood is closed.
Navigate: Go to Coding & Service > Doors, Locking and Unlocking.
Select Option: Look for "Disable automatic locking of the fuel door while driving" or a variation labeled "Fuel Flap Lock".
Change Value: Change the setting from Disabled to Enabled (or vice versa, depending on whether you want to activate or deactivate the safety feature).
Save: Tap Write to code the changes into Central Electrics (Module 09).
Thanks @serdar_18fr for quick reply. Have checked in english version of Car scanner the options you've suggested. Found only 2 connected a bit with fuel flap:
1. Autolock rear part of the car [act./inact.]
2. Type of fuel tank flap motor [bidirectional/unidirectional]
First one does not do the job [fuel flap still auto locks after moving] - have no idea which rear part of the car it is for.
Second one after setting "Unidirectional" does not lock fuel flap when I lock the doors - one may open it and get to the fuel tank cover.
Have seen a clip on YT where a buddy coded this with OBDeleven in Seat Ateca MY2021. Flap locked when driver closed the doors and did not auto locked after moving. I'm afraid there's lack of this option in car scanner. I'm using MQB, PQ26 TSI/TFSI 1.5
I looked at my OBD11 now and found the "geschwindigkeitsabhaengige tankdeckelverriegelung" entry under the ZV Autolock heading in adaptations. If there's a similar menu concept in Car Scanner app like headings and sub-entries, you might want to look for a "central locking autolock" (ZV is for zentralverriegelung which means central locking) or something similar.
Checked again carscanner connected to a car. Even changed language to German. There is a section between many others "Doors, locking and unlocking" and inside there are many options to set up [including those 2 mentioned in my previous post]. Having the app in German did not find " zv autolock". Generally it's different than in OBD11 where one can firstly choose module and next get into adaptations available in this module. In carscamner modules are mentioned in "Long coding" but bytes are undescribed and there is no link do adaptations. Suspect I can't deactivate fuel flap autolock in Seat via Carscanner.
Finding someone in your area who has an OBD11 is the best bet then.
How about checking in OBD11 which byte and bit changes in module 09 long coding after deactivate this adaptation? Then I could try to change the same in module 09 Car Scanner long coding. Would anyone be so kind and check it?
Adaptation channels and long coding entries are stored separately. Changing the value of an adaptation entry does not change the long coding.
