Car scanner pro app coding
G_mac86
29
10
Can you code in full led flash?
After paying for the full app I could code this in so fog lights flash with full beam flash - they don't come on when full beam on all the time. Haven't really looked at the other coding options yet, but worth what I paid, plus I got a discount on the app through play store!
b1ggus
9
Tried this today with my son's 2017 Leon SC 1.4 150 FR Tech and enabled needle sweep, unhelpfully called 'Test pointers at engine start', and also visual Park Pilot with only rear sensors using the long coding...
1 - Module 76 - Assisted parking
2 - Extended coding (Bytes Mode)
3 - Byte 2 - (Activate Bit 0)
The sensors now display visually but the actual beeping no longer accompanies them, is this right or have I missed something?
Secondly, how would I do something like this using the app...
1 - Module 09 - Electronic control unit - Code (31347)
2 - Adaptation
3 - Spiegelverstellung
4 - Funk spiegelaklappung modus - (Change value to By look command via remote control key)
...as going to Module 09 in the menu only offers changing Bytes
Daggerw9
14
Hi all thought id post up a bargain.
On the play store this app can perform long coding and adaptations to all the seat audi vw range and cost like 3 quid.
So far i have done
Needle sweep
Engine torque limitation
Drl off with switch in off position
Drl dim with indicators.
Esc options esc off and esc sport
The weekend i am installing rain light humidty sensor for auto light and wipers.
The app is really good and works with elm 327 thought id let yall know
Where is the option for the needle sweep in car scanner I have the full paid version
kazzz25
31
2 - Adaptation
Where did you get this information? I mean to know how to code park assist? Is there a long coding guide or something? I'm looking to get rear LEDs to come on as part of DRL. Thanks
ARH
24
13
from post 22 above "enabled needle sweep, unhelpfully called 'Test pointers at engine start'," I believe in dashboard settings
