Well, since posting the garage have said they are a bit suspect about the abs test/refurb, so for free, they said they are going to use their golf abs module as a donor & see what happens. If it improves then my unit's fee will be refunded & the car might start behaving. I really don't know otherwise.
Your ECU idea is interesting. Unfortunately the two front wheels apparently have bound on with car started, but cold, literally after meters of driving, so even more confusing to me.
I think that's the least they can do considering what's happened. They need to get this sorted for you.
ECU has zero control over anything brake related.
Hi there friends.
I have no update on my car, other than I think it it has reached the end.
I'm out of luck, money & determination & now I just need to get it home for good.
Nothing has changed, despite my best efforts, so I decided this morning to call it a day.
I'm at a loss in every way, but worst of all my spirit crushed. I've done everything I can, but I'm not made of money.
I hope (even if my car stays on the driveway as a non-runner), I will still be accepted as part of this forum, because you have all been so helpful in trying to get this car off the starting blocks again. I have a heavy heart, but I see no light at the end of the tunnel & so I have to regain some control of it again.
I don't know how I'm going to get it home, because the binding is apparently worse than before. 😣
Cheers for all your support friends, I really do appreciate it 👍
BadBoy
crap news mate , i had MK1 Clio 16V and when it was warm whether i use to get a power drop and when it did it used oil, i had it wired upto the moon and tested allot there was no problem yet in cold it never happened do know the feeling
Reactions: BadBoy03
Thanks Nam, I appreciate it. Yeah, it's a nightmare I just want to end. I only want it back as it was, and despite the system being relatively basic, it's become a minefield that I can't seem to get through for love or money.
Fingers crossed for the next few weeks 🤞
Thanks for clarifying that mty, I couldn't see how it would affect it, but I think I'm so desperate, I'm trying to explore all variables. 😣
hopefully the doner unit works and at least the garage questioned it instead of fobbing you off as it looks like they don't want to give up, it does seem its not a big problem i mean its not like a engine even ecu/electric fault
Finally, after 6 months since the crash I had in February, the car is driveable again and has just passed its MOT. 👍
I'm now taking it to Poland for a proper rebuild, so hopefully around May/June next year I'll finally have the chance to enjoy it again. 🤞
It's been a long road, but we're getting there.
Was the exhaust original? A what the new one cost ?
Yes, I think the exhaust that came off may have been the original or if it had been replaced at some point was a genuine Seat part.
As to the cost, via eBay from Roadrunner Motorsport - £528 delivered.
I've no idea if that was a good price, but I'd had it bookmarked for last couple of years in anticipation of needing one.
Reactions: Nam-uk
I've owed the car a bit of work, as I haven't done any big jobs for a couple of years now. When it runs and drives so well, you kind of forget. Got a few advisories I don't want to fix until I've done a big job next week - if it goes south, it might mean scrapping the car, so there's no point doing other jobs before that.
Took the engine cover off to work out how I'm going to do it and noticed my fuel line is cracking.
Thought the bend I made when I put it in was pretty relaxed, so didn't think that it would do that, but it's doing the same thing on the curve where my hand is too, so I'm glad I caught it. I put that one in as I had to replace the OEM one, as they don't make that one anymore - it's shaped and has ninety degree bends and stuff to make it go round the corner to the tandem pump.
Any recommendations on fuel hose? This is just a Halfords one, so I wouldn't expect it to be the best lasting. Could have caused me a few problems if it had given up...
Reactions: BadBoy03
Gates who do the Cam belts do fuel lines i used the pipe were you used it but cut at same length then used a heat gun to warm it up for the bends , just don't go mad on heat, i have changed it twice though since 2012 due to the first one did get cracks but i never warmed up for the bends
Brake pads are paper thin but not getting the dash light on. Turns out the plug is missing.
Just wondering what I'm looking at. Looks like it's had a heat shrink on from a previous repair?
Anyway, is 1J0973802 the right code for ours?
Used AI seems it’s right , oh and you can get soilder crimp connectors, crimp and heat up they work well
Reactions: Alexis27
Auto Silicone Hoses do fuel line in various sizes - good quality and service (well for me anyway)
Reactions: Nam-uk
That's a good shout - the other hose I did at the same time had a more gentle curve to it and that's fine still, so I'll try better quality hoses and get the heat gun out.
Currently want to throw the car in the bin. I'm about eleven allen bolts into an eighteen allen bolt job and one of them has decided it wants a fight and it's threatening to round out - and that's before the six bolts I'm expecting to be worse. Car is undriveable right now, TIP is out, hands are filthy, arms are cut up from various VW hose clamps on coolant lines, ground around the car is covered in coolant, and I'm exhausted. I'm not going to back down at this point, given I'm about 80% of the way in, but now's the time I start doing stupid things and make everything worse, when I just need some longer allen sockets, so I'm going to take a beer into the shower, maybe have a little cry, and then have some dinner.
At least now I've lost some coolant, I can replace my thermostat. I'll bet that fights me too.
******* Leon life.
******* Leon life.
I feel your pain...I've moved on to Vodka 😬
Best of luck, I hope you get a breakthrough 👍
Reactions: iammooks
Thought I'd at change the thermostat while I wait for a tool to arrive. Since I've lost some coolant, I'm not going to miss any more that comes out when I take the old one out. Looks like doing it properly means taking the alternator out.
******* Leon life.
Thanks for the good wishes - I'm visualising the bolt coming out easily once I get the right tool on it.
Or else it gets the hacksaw.
  • Haha
Reactions: BadBoy03
