Ibiza Cupra 1.8t injector O-rings?
cuprabaz
Racing 2020VT
Jun 22, 2004
2,291
Aberdeenshire
My injectors seals/o-rings are weeping, anyone know the size so i can get some before i take them apart.
I've got plenty of o-rings at work so i'll only need the id and the od of the o-ring.
cheers
Barry
flashbsd
will be the seals mate, if you find the right size, get me 4 :)
cuprabaz
Racing 2020VT
Jun 22, 2004
2,291
Aberdeenshire
m0rk said:
are you sure it's the O rings & not the seals?
Ah!! Not sure m0rk, when i put the evo gasket on there was loads sh*te all around the injector and surrounding area which i always thought was the rocker cover leaking but it turns out the gold coloured gunk is from the injectors.
When you say the seals you mean the black rubber one's attached to the mani itself. Probably best buying those aswell just to eliminate them.
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
I thought the ones I saw last weekend were grey - but a seals a seal - and I think they're all of £0.60ea anyway
Nov 2, 2004
9,334
South Wales
Does anyone know the part number for these so i can check?
Just ordered some from Seat and they charged me £2.42 each plus VAT. Doesnt sound right to me.
Tony 156
468
Thatcham
ah nice to know its not just me leaking then.
they will expensice from seat for sure, changed mine but didnt help but think it should be ok for a while yet.
R0b
104
Sorry to top this thread but i have the same problem.
Looks like my injectors are leaking as there are stains all over the surrounding area. My cars booked in for a service at Seat on the 31st, shall i get Seat to change them while car is there or shall i get the parts elswhere and get someone else to do the job? Surely it can not can not cost much?
ganda_cupra
VW Commercial Technician
Sep 4, 2006
286
Near Sheffield
Injector O-rings x8 __________ 035 906 149A ___ £2.35 each
Inserts into inlet manifold x4 __ 06b 133 555H ___ £1.09 each
Inlet manifold gasket ________ 058 129 717D ___ £2.69
Inlet manifold Bolts x8 _______ N10 080 102 ____ £0.46 each
Fuel rail bolts x2 ____________ N0147404 ______ £0.39 each
Thats the parts I used when I changed my Injector seats and injector O-rings.
Hope that helps, P.s I didn't pay those prices got them at cost.
I'd advise taking the inlet manifold off if your changing the injector seats/inserts, as debris falls on top of the valves. Also i had to chisel one of them to bits as it wasn't coming out.
ganda_cupra
Sep 4, 2006
286
Near Sheffield
I work at a VW garage so get everything at cost price should have come to around £36, i paid around £23 for all the above.
On etka next to the part number in the remarks section where sizes are usually noted it states 7,52x3,53. Hope that helps forbez.
Spud_G40
PS3 Gamer tag: SRedx
Jun 12, 2006
397
Glasgow
Is the gold stuff your talking about not oil coming through from the oil breather pipe coming from the PCV valve into the inlet manifold?
Mine has this too, Should I think about replacing seals too? (having blanked this pipe off)
