Ibiza Cupra 1.8t injector O-rings?
flooky
Has anyone had problems trying to fit these? Cant seem to get the rail back onto the inlet. Ive used the oe part number 035 906 149 A
The new O-Rings are fatter than the ones ive taken from the bottom of the injector. Cant see no way of getting the injector back on.
cheers
flooky
Yeah I thought so, well there are already 2 different sizes on their at the moment and VW are telling me there is only 1 type. Would anyone know the other part number?
I would have a look but im away and using my phone which is not easy!
Thanks.
flooky
Can anyone confirm when replacing the o-rings with 035 906 149A, does the injectors take a lot of force for them to pop into the inlet? I've tried 3 times now and they wont go in, the old ones pop in with one hand!
VW are saying the above part number is the only one listed.
greg
Newbie
Aug 31, 2005
256
I replaced mine a few weeks ago and they were definitely identical top and bottom. Went on no problem too and were the same size as the ones i took off.
Oct 31, 2006
870
Cambs
the injector seats are threaded so you can screw them in and out, although they maybe brittle and you might end up smashing them out, you'll need a 20mm allen key to fit them though
emlyn11
358
Surrey
Thanks for the fast response :)
Should I use some sort of sealant/loctite etc when I put them back in or just
put them in dry?
Emlyn
