20mm spacers with standard Cupra wheels
Jan 8, 2007
2,958
Wiltshire
Anyone had any rubbing issues running 20mm spacers on the standard Cupra alloys when lowered?
I'm running 15mm on the back at the moment but they still don't stick out as much as I'd like.
TIA,
Rob
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
i have 20mm on rear with standard cupra rims lowered with h+r kit and it rubs the outside off the tyre wall if i go in a big ditch/dip fast. hardly ever though so is worth it.
weekesj
Hates the Cupra rattles
Feb 17, 2008
312
Herts
Tiny bit of stretch on the tires might cure slight rubbing issues?
20mm looks so much better than 15mm.
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
I have 20mm spacers and use them with both my 15"BBs rims which are 6j wide and my wide rim 16" which are 7.5 wide and get very little scrubbage tbh. (only as said , with a car-load and rough terrain)
Davem
145
Birmingham
down about 40mm.. 20mm spacers on rear of mine and get abit of scrapping when got someone in back and hit a bad ditch at speed. so nothing to worry about.
dubz_wm
DuBaHolIcS.co.uk
Jul 25, 2008
306
Wimbledon, Surrey
mine is slammed....ish on 20mm rears with alot of stretch and i do get the occasional rub, but nothing really to worry about tbh. well worth it for the handling and the stance.
