abs sensor fitting
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
HI all,
I have done searches but nothing showing on the fitting of the sensors, does anyone know if when i have fitted the sensors the fault codes will need to be re set, or will the car know that there is no longer a fault and switch the warning light off, or will i need to go through any re setting processes.:confused:
The MoffMeister
Half Hoff, Half Moff.
Apr 4, 2006
2,937
colchester
battery reset should do it
disconnect both battery terminals for 30 mins or so then put back on this should work if not a vag com reset, but you should be ok
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Yeah i will be disconnecting the battery any way, i am planning on getting vegcom but need a lap top first or a very long lead from my pc. so if the codes still show i will be able to deal with it then.....NOT paying Seat Derby £65 for two minutes work.
The MoffMeister
Apr 4, 2006
2,937
colchester
goto the meets section for where you live and ask if anyone has vag com on a laptop so you can meet new people and theirs always someone who'll help you out
