Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
HI all,
I have done searches but nothing showing on the fitting of the sensors, does anyone know if when i have fitted the sensors the fault codes will need to be re set, or will the car know that there is no longer a fault and switch the warning light off, or will i need to go through any re setting processes.:confused:
battery reset should do it
disconnect both battery terminals for 30 mins or so then put back on this should work if not a vag com reset, but you should be ok
Yeah i will be disconnecting the battery any way, i am planning on getting vegcom but need a lap top first or a very long lead from my pc. so if the codes still show i will be able to deal with it then.....NOT paying Seat Derby £65 for two minutes work.
goto the meets section for where you live and ask if anyone has vag com on a laptop so you can meet new people and theirs always someone who'll help you out
