Coming back from a friend's house this evening I come to traffic lights, go to pull away and nothing, pressing the throttle and no response
So got it trailered home and got the code scanner out,
18039- Accelerator Position Sensor (G79): Signal too High
P1631-35-00
18042- Accelerator Position Sensor 2 (G185): Signal too High
P1634-35-00
The EPC light is also stayed on.
According to this, http://forums.vwvortex.com/zerothread?id=3081081 and this http://www.seatcupra.net/forums/showthread.php?t=177103&highlight=18039&page=2
FRIED ECU??
Is the ECU easy to replace? Can the map be transfered somehow from my existing ECU to replacement?
OR could it possibly be that one of the acceleration sensors has caused my recent boost problems and finally failed? Is that likely? Seemed to be the case here: http://www.passatworld.com/forums/archive/index.php/t-227645.html
Epic help required
So got it trailered home and got the code scanner out, 18039- Accelerator Position Sensor (G79): Signal too High
P1631-35-00
P1634-35-00
FRIED ECU??
Epic help required
