thats what i have planned. the allard pipe is 57mm so i need to order up the right silicone hose, do you know what size the aluminium pipework is where the 90 degree standard hose connect from to go to the egr?? i have a feeling it is the same but not sure??
Not sure tbh!!
remember our egr has the cooler so it is water cooled...can't remove that alltogether...if so how?
The older EGR's like the one that was on my PD130 53 plate are the older vacuum powered EGR's. On the newer cars, like 07 & 08 plate FR Pd130's for example, they are electricially powered and you cannont replace those with an EGR removal pipe.
You have a pipe going from the turbo/manifold to the EGR. You literally remove the EGR and that pipe all in one. Just put the blanking plate on the turbo and the straight pipe where the EGR was - leave it like that.
