APY whats the differnce?
micknoon
Hi all, I'm strugiling to find a AMK or BAM engine but came across a APY, dose anyone know if this will go straight in my 210 LCR with no hassel and if i used all my sensors would a be ok to use my ecu? a found a spread sheet with info but dont know hears a link to the spread sheet, thanks michael
http://www.clubgti.com/forum/showthread.php?t=34368&page=4
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
APY is the early S3 210 engine. Non-drive by wire throttle, and non-VVT. I think there's EGT Sensor differences.
You could get it to fit and run, but it'd be a lot more work than an AMK or BAM
Dani_b19
301
Eh, my apy has DBW and its debatable about VVT, some say it has mechanical VVT so say it hasnt got it. Also the APY block has afew less sensors than the BAM/AMK.
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Errr, I might be mixing up my AGUs and APYs. Anyway. APY and AMK/BAM not a "no hassel" swap.
micknoon
Hi all, a don't know what dbw or vvt not got a clue and if it has less sensors would my ecu run the car ok
Thanks for you're replys michael
Dani_b19
301
DBW=Drive By Wire, VVT=Variable Valve Timing. So did you have a 210 engine in before? Has it died or something and thats why you need a new one?
micknoon
Yeah mate had a AMK early LCR and it dropped a rod and it came through the block, so engine is gubbed so do u think it would be a straight fit as no got the money for more hassel, thanks michael
Dani_b19
301
Depends if the new apy block has esp or not, if it hasnt then your going to struggle, if it has esp then its not 2 bad but the apy block does have fewer senses than the bam/amk block so thats were you may struggle. Fverything else is the same tbh.
micknoon
Am thinking am goiny just try get a AMK or BAM cause cant be fecked with the hassel, would any other engine fit or is that my only choices? thanks michael
