Ashtray
S21RUB
Yeah might be worth a look. Has anyone replaced in with anything else? Wondering about fitting an iphone holder in it's place.
M14KCY
New
Jan 26, 2009
171
Scotland
Nice one. Think i will pull mine out later and have a look, failing that i'll just need to bite the bullet and get a new one.
Mine does that creekin noise too so might be the ashtray, hopefully that will sort itself out when i've fixed the ashtray, the dash can be a real pain in the a**e sometimes with the ratlles.
The back of my car squeaks too around the seats it sounds like.... Can be really annoying when music is down low.
Jblaze
25
you dont need a new one its a simple fix takes 10 mins ... remove it by unsrewing the screw under the pull out ash part .. look in side it and there is a little pin you need to push it back and it will work again there are pics some where on this site .. your see what i mean when you take it apart tho
I've opened mine, but I can't see that pin :(. Can someone help me finding these pictures or explain me in details how to try to fix it?
PS If it's worn out and needs a replacement can I get from Toledo or it's different one?
Scam
144
London
If the pin has gone (lost it...) then unless you can find something that matches it precisely - you're better off getting a whole new ash tray. I tried fixing mine with othe similar size pins, but the plastic surrounding the pin was shot.
Lesson learned - the ashtray can only hold so much weight in loose change :cartman:
A toledo one should be fine.
Jblaze
25
I posted pics up recently, will be on here somewhere
Thank you for the directions. I've found those pics and in the same thread there was a link to another one (seatcupra.net/forums/showthread.php?t=357246), in which I found pics how to fix the broken pin. Superglued it (and the broken plastic around it) and it's staying shut for now. It even takes 3 or 4 pushes to open it, but since i'm not a smoker and there is a no smoking rule in the car, it satisfies me.
Luckily or not the pin was still inside, so it's fixed for now. Let's hope it will last at least a year :funk:.
