On one of the runs we logged even though throttle was 100% down, the plate closed to 40% briefly. Not sure if that was the ECUs last ditch attempt at cutting boost or something?!?!?
Its a K03S yeah.
Modifications are:
Forge Motor sport front mounted intercooler
Forge Motor sport turbo intake pipe
Forge Motor sport diverter valve (yellow spring)
Green cotton air filter element
Denso Iridium IK22 spark plugs (0.8mm gap)
Milltek Hi flow sports cat and downpipe (2 ½ inch)
Milltek full cat back exhaust system (2 ½ inch)
Spec Stage 2 clutch
Peloquin LSD
The map was done by CC.
Could it be a faulty N75? (I have no idea to be honest!!!)
Doubt it's the N75. You can see the ECU pulling the load back in 003.
A log of 114 would be interesting.......
Have you mentioned the problem to CC?
The timing is very conservative too. I would expect some CFs from a stage 2 remap.
Agree, the boost is not meeting spec, there is no leak because the Duty Cycle is no more than 95% but it suddenly drops off at 5360 rpm, where I would expect it to still be at full boost.
2320 millibar is 1.42 bar (if you minus absolute) = 20psi. I belive that is pretty high for a K03s.
Would this drop off of boost result in the throttle valve closing as well Dave?
I can probably log 114 tonight. (what does that show?)
They said they only noticed the problem happen once and WE should look into it but wasnt that important.
Now we have the car its quite clear it happens every time!
They seemed to know their stuff but when it came to suggesting ideas for the fault they seemed stummped to be fair. Like I say they fitted a 4 BAR and his other suggestion was to swap the N75.
Not sure 100% but in my opinion fitting a 4 bar will have done nothing for fuel pressure if the standard pump can only do 3 (and he seemed to think it wasnt putting out 100% so call it 2.8 lol).
Another thing thats maybe worth mentioning is the car has Eurocarparts Lambda sensors not genuine VW ones if that matters? Everything is usually OEM but the price for new lambdas from VW was a joke.
114 shows specified load, and load corrections with duty cycle.
Std pump puts out a lot more than 3 bar. 4 bar fuel pressure increases the amount of fuel at each injection. It looks like it's mapped for it.
You've just had my opinion so far (and I can't see the cause yet) - wait until you get some more comments...
Nothing wrong with ECP stuff - except some of the really cheap alternatives they offer...
Wow, this sounds familiar.
Oscillating boost. Basically your actual is pulled back by the ecu after hitting more than whats requested, as it drops below requested it goes back up then drops again if spikes more etc...
I've had the twice on the rollers, where the atcual spike is way up on requested the ecu '**** itself'
You can see it on two rollers...
Westec...
http://img.photobucket.com/albums/v147/philwarren11/BHP11-NOV-2007.jpg
http://img.photobucket.com/albums/v147/philwarren11/Torque11-NOV-2007.jpg
And Powerstation...
http://img.photobucket.com/albums/v147/philwarren11/Cupra/DSCF0976.jpg
I think i might have cured this by using a Greddy Profec EBC, but i'll soon find out when i'm due to go back to Powerstation a week Saturday.
I've been trying to find a thread on it on vortex but i cant find it now for the life of me.
Also
Sorry for the missing names, but you can tell what they are.
Theres a few people with the 4.5k dip, iirc Benny got it on his k03s stage 3 Revo.
On the dyno run they did (they did 3 or 4 pulls, presumably took the best) there were no dips in power visible.
When driving it only feels like small dips but the logs suggest its clearly doing something wrong.
It can be noticable throught the range at various points but usually its just around 6000.
I will try post the dyno graph up in a bit. Like I say though, you will see its strange that they stop at 6100 and its usually around then when it has its dip/hesitation.
EDIT....
DPJ - Do the lambda readings look OK? I didnt know if it was running a bit lean top end.
Here is some data from 114. Its a really long log and I'm not sure which bit was WOT. If needs be I can do another run with JUST the run data.
Code:
	Group A:	'114
		Eng Load Call	Corr. Load	Engine Load	Bypas Dut Cyc/0-100%
	TIME	<=150%	<=150%	15-150%
Marker	STAMP	%	%	%	%
	0.72	115.8	114.9	85.7	95.3
	1.23	118.8	117.9	89.5	95.3
	1.91	122.6	120.9	94	95.3
	2.46	130.1	128.4	98.5	95.3
	3.04	136.1	134.3	104.5	95.3
	3.64	167.7	167.2	111.3	95.3
	4.24	181.2	180.6	122.6	95.3
	4.76	185.7	185.1	136.1	95.3
	5.35	191.7	191	157.1	95.3
	5.86	191.7	195.5	178.2	95.3
	6.46	191.7	200	191.7	86.7
	6.96	191.7	201.5	191.7	82.4
	7.47	191.7	204.5	191.7	80.8
	8.12	191.7	207.5	191.7	78.8
	8.67	191.7	206	191.7	80.8
	9.27	191.7	206	191.7	81.6
	9.78	191.7	209	191.7	83.1
	10.29	191.7	210.4	191.7	84.7
	10.88	191.7	207.5	189.5	87.5
	11.38	191.7	204.5	187.2	95.3
	11.89	191.7	203	182.7	95.3
	12.49	191.7	201.5	177.4	92.2
	13.1	191.7	198.5	172.2	95.3
	13.79	191.7	197	165.4	95.3
	14.37	191.7	194	162.4	95.3
	14.92	191.7	192.5	160.2	95.3
	15.51	191	191	156.4	95.3
	16.02	190.2	189.6	151.9	95.3
	16.52	189.5	188.1	150.4	95.3
	17.16	188	186.6	148.9	95.3
	17.74	188	186.6	146.6	95.3
	18.33	188	186.6	144.4	95.3
	18.85	188	186.6	142.9	95.3
	19.47	188	186.6	142.1	95.3
	20.13	188	186.6	138.3	95.3
	20.65	188	186.6	139.8	95.3
	21.26	188	186.6	20.3	0
	21.85	191.7	194	12	0
	22.45	191.7	197	12	0
	23.05	191.7	198.5	12	0
	23.55	191.7	204.5	12	0
	24.06	191.7	206	12	0
	24.56	191.7	206	12	0
	25.17	191.7	203	12.8	0
	25.84	191.7	203	12	0
	26.41	191.7	203	12	0
	26.97	191.7	203	12.8	0
	27.58	191.7	204.5	12.8	0
	28.18	191.7	204.5	12	0
	28.79	191.7	204.5	12.8	0
	29.4	191.7	203	12.8	0
	30	191.7	201.5	12.8	0
	30.59	191.7	201.5	12.8	0
	31.2	191.7	200	12.8	0
	31.85	191.7	200	12.8	0
	32.43	191.7	198.5	16.5	0
	33.01	191.7	198.5	45.1	0
	33.52	191.7	198.5	52.6	0
	34.11	191.7	198.5	48.9	0
	34.63	191.7	200	51.9	0
	35.22	191.7	200	39.1	0
	35.74	191.7	200	35.3	0
	36.34	191.7	198.5	33.1	0
	36.93	191.7	200	47.4	0
	37.56	191.7	200	49.6	0
	38.2	191.7	200	50.4	0
	38.75	191.7	198.5	68.4	0
	39.36	191.7	198.5	53.4	0
	39.95	191.7	200	51.1	0
	40.46	191.7	200	42.9	0
	41.06	191.7	200	37.6	0
	41.66	191.7	198.5	37.6	0
	42.26	191.7	198.5	42.9	0
	42.77	191.7	198.5	48.1	0
	43.37	191.7	198.5	40.6	0
	44.04	191.7	198.5	40.6	0
	44.58	191.7	198.5	57.1	0
	45.19	191.7	198.5	54.9	0
	45.78	191.7	198.5	54.9	0
	46.39	191.7	200	54.9	0
	46.99	191.7	200	60.2	0
	47.59	191.7	200	57.1	0
	48.2	191.7	200	52.6	0
	48.72	191.7	200	51.9	0
	49.32	191.7	200	55.6	0
	50	191.7	200	54.1	0
	50.53	191.7	200	51.9	0
	51.11	191.7	200	51.1	0
	51.72	191.7	200	49.6	0
	52.33	191.7	200	45.9	0
	52.93	191.7	200	45.9	0
	53.53	191.7	200	45.9	0
	54.15	191.7	200	52.6	0
	54.74	191.7	200	51.1	0
	55.34	191.7	200	51.1	0
	56.02	191.7	200	51.1	0
	56.56	191.7	200	51.1	0
	57.15	191.7	200	51.1	0
	57.75	191.7	200	51.1	0
	58.37	191.7	200	51.1	0
	58.96	191.7	200	50.4	0
	59.57	191.7	200	51.1	0
	60.16	191.7	200	51.1	0
	60.78	191.7	200	48.9	0
	61.38	191.7	200	49.6	0
	62.03	191.7	200	49.6	0
	62.58	191.7	200	49.6	0
	63.19	191.7	200	48.9	0
	63.79	191.7	200	43.6	0
	64.4	191.7	200	41.4	0
	65	191.7	198.5	12	0
	65.59	191.7	198.5	12	0
	66.2	191.7	197	13.5	0
	66.7	191.7	197	13.5	0
	67.31	191.7	197	13.5	0
	67.98	191.7	197	13.5	0
	68.52	191.7	195.5	13.5	0
	69.12	191.7	195.5	13.5	0
	69.62	191.7	195.5	13.5	0
	70.23	191.7	195.5	13.5	0
	70.82	191.7	195.5	14.3	0
	71.43	191.7	195.5	13.5	0
	71.93	191.7	195.5	13.5	0
	72.43	191.7	195.5	13.5	0
	73.04	191.7	194	13.5	0
	73.58	191.7	194	13.5	0
	74.2	191.7	192.5	13.5	0
	74.75	191.7	192.5	13.5	0
	75.35	191.7	191	13.5	0
	75.95	189.5	188.1	13.5	0
	76.57	186.5	185.1	12.8	0
	77.16	182.7	182.1	12.8	0
	77.66	179.7	179.1	13.5	0
	78.27	154.1	153.7	12.8	0
	78.87	133.8	132.8	12.8	0
	79.53	128.6	126.9	12.8	0
	80.14	191.7	194	12.8	0
	80.68	191.7	195.5	14.3	0
	81.19	191.7	191	14.3	0
	81.79	183.5	182.1	14.3	0
	82.4	127.1	125.4	14.3	0
	82.99	115.8	114.9	15.8	0
	83.51	115	113.4	13.5	0
	84.1	112	110.4	15	0
	84.7	112.8	111.9	33.1	0
	85.31	113.5	111.9	36.1	0
	85.98	114.3	113.4	39.8	0
	86.52	115.8	114.9	44.4	0
	87.12	117.3	116.4	30.8	0
	87.63	118	116.4	27.8	0
	88.22	118	116.4	27.1	0
	88.73	118.8	117.9	36.8	0
	89.23	120.3	119.4	79.7	95.3
	89.83	124.1	122.4	89.5	95.3
	90.34	129.3	128.4	94.7	95.3
1	90.84	135.3	134.3	100.8	95.3
	91.35	148.1	146.3	106.8	95.3
	92.03	178.9	177.6	116.5	95.3
	92.55	183.5	182.1	130.1	95.3
	93.17	189.5	188.1	149.6	95.3
	93.77	191.7	194	174.4	95.3
	94.36	191.7	197	191.7	89
	94.96	191.7	200	191.7	83.5
	95.57	191.7	206	191.7	81.2
	96.08	191.7	207.5	191.7	81.6
	96.67	191.7	204.5	191.7	81.6
	97.28	191.7	206	191.7	84.3
	97.96	191.7	209	191.7	85.5
	98.5	191.7	209	191.7	89.8
	99.1	191.7	206	188	84.3
	99.7	191.7	203	182.7	79.2
	100.19	191.7	201.5	179.7	95.3
	100.71	191.7	200	175.2	95.3
	101.3	191.7	201.5	10.5	0
	101.8	191.7	203	11.3	0
	102.3	191.7	206	11.3	0
	102.81	191.7	207.5	12	0
	103.42	191.7	206	12	0
	104.09	191.7	204.5	12	0
	104.62	191.7	200	12	0
	105.12	191.7	198.5	12	0
	105.62	191.7	198.5	13.5	0
	106.24	191.7	197	30.1	0
	106.83	191.7	197	54.9	0
	107.33	191.7	197	55.6	0
	107.94	191.7	197	79.7	0
	108.55	191.7	198.5	138.3	95.3
	109.15	191.7	200	191.7	83.9
	109.81	191.7	203	191.7	79.6
	110.4	191.7	204.5	191.7	80.8
	110.95	191.7	206	191.7	80.4
	111.56	191.7	207.5	191.7	79.2
	112.07	191.7	206	191.7	80
	112.66	191.7	204.5	191.7	80.8
	113.17	191.7	204.5	191.7	80.8
	113.68	191.7	203	191.7	82
	114.28	191.7	203	191.7	81.6
	114.89	191.7	203	191.7	82
	115.41	191.7	204.5	191.7	82.7
	116.05	191.7	204.5	191.7	82.7
	116.6	191.7	204.5	34.6	0
	117.19	191.7	203	11.3	0
	117.79	191.7	203	12	0
	118.31	191.7	203	12	0
	118.9	191.7	203	12	0
	119.4	191.7	203	12	0
	119.91	191.7	204.5	12	0
	120.52	191.7	204.5	12	0
	121.11	191.7	204.5	12.8	0
	121.8	191.7	204.5	82	0
	122.36	191.7	204.5	54.9	0
	122.92	191.7	204.5	117.3	52.2
	123.54	191.7	204.5	119.5	29.4
	124.14	191.7	206	94	18.8
	124.74	191.7	204.5	88.7	0
	125.26	191.7	206	78.9	0
	125.87	191.7	206	70.7	0
	126.44	191.7	206	63.2	0
	126.96	191.7	206	60.9	0
	127.6	191.7	206	58.6	0
	128.23	191.7	206	63.2	0
	128.77	191.7	206	69.2	0
	129.36	191.7	206	69.9	0
	129.96	191.7	206	65.4	0
	130.47	191.7	206	24.8	0
	131.07	191.7	206	11.3	0
	131.57	191.7	206	19.5	0
	132.07	191.7	206	38.3	0
	132.6	191.7	206	44.4	0
	133.18	191.7	206	57.1	0
	133.88	191.7	206	62.4	0
	134.51	191.7	206	63.2	0
	135.1	191.7	206	57.9	0
	135.72	191.7	207.5	48.1	0
	136.3	191.7	207.5	45.9	0
	136.91	191.7	207.5	62.4	0
	137.52	191.7	207.5	63.2	0
	138.11	191.7	207.5	65.4	0
	138.71	191.7	207.5	66.2	0
	139.24	191.7	207.5	63.9	0
	139.91	191.7	207.5	62.4	0
	140.46	191.7	207.5	62.4	0
	141.03	191.7	207.5	54.9	0
	141.56	191.7	207.5	52.6	0
	142.13	191.7	207.5	48.1	0
	142.65	191.7	207.5	47.4	0
	143.24	191.7	207.5	46.6	0
	143.74	191.7	207.5	46.6	0
	144.25	191.7	206	46.6	0
	144.85	191.7	206	46.6	0
	145.35	191.7	206	47.4	0
	146.02	191.7	206	47.4	0
	146.57	191.7	206	47.4	0
	147.17	191.7	206	47.4	0
	147.78	191.7	206	47.4	0
	148.38	191.7	206	47.4	0
	148.98	191.7	206	47.4	0
	149.57	191.7	206	47.4	0
	150.08	191.7	204.5	47.4	0
	150.68	191.7	204.5	47.4	0
	151.28	191.7	204.5	47.4	0
	151.97	191.7	204.5	45.9	0
	152.51	191.7	204.5	47.4	0
	153.09	191.7	204.5	45.9	0
	153.7	191.7	204.5	44.4	0
	154.2	191.7	204.5	44.4	0
	154.8	191.7	204.5	64.7	0
	155.32	191.7	204.5	56.4	0
	155.92	191.7	204.5	54.1	0
	156.52	191.7	204.5	78.2	0
	157.12	191.7	206	78.9	0
	157.8	191.7	206	64.7	0
	158.38	191.7	206	57.9	0
	158.93	191.7	206	50.4	0
	159.44	191.7	206	48.1	0
	160.04	191.7	206	45.1	0
	160.65	191.7	206	42.9	0
	161.25	191.7	206	42.9	0
	161.85	191.7	206	43.6	0
	162.45	191.7	204.5	48.1	0
	162.95	191.7	204.5	46.6	0
	163.59	191.7	204.5	47.4	0
	164.25	191.7	204.5	47.4	0
	164.76	191.7	204.5	47.4	0
	165.37	191.7	204.5	48.9	0
	165.97	191.7	204.5	54.9	0
	166.57	191.7	204.5	53.4	0
	167.18	191.7	204.5	54.1	0
	167.69	191.7	204.5	54.9	0
	168.28	191.7	204.5	54.1	0
	168.89	191.7	204.5	54.9	0
	169.39	191.7	204.5	54.9	0
	170.05	191.7	204.5	54.9	0
	170.6	191.7	204.5	56.4	0
	171.2	191.7	204.5	56.4	0
	171.7	191.7	204.5	56.4	0
	172.32	191.7	204.5	56.4	0
	172.92	191.7	204.5	63.9	0
	173.43	191.7	204.5	63.9	0
	174.02	191.7	204.5	63.9	0
	174.63	191.7	204.5	66.2	0
	175.22	191.7	204.5	81.2	0
	175.9	191.7	204.5	81.2	0
	176.46	191.7	206	81.2	0
	177.04	191.7	206	85.7	0
	177.65	191.7	207.5	87.2	0
	178.24	191.7	207.5	85	0
	178.74	191.7	207.5	50.4	0
	179.35	191.7	206	12	0
	179.96	191.7	206	12.8	0
	180.55	191.7	204.5	12.8	0
	181.06	191.7	203	12.8	0
	181.73	191.7	203	12.8	0
	182.32	191.7	203	12.8	0
	182.88	191.7	201.5	12.8	0
	183.47	191.7	200	12.8	0
	184.07	191.7	198.5	12.8	0
	184.58	191.7	198.5	28.6	0
	185.18	191.7	197	16.5	0
	185.68	191.7	197	12.8	0
	186.28	191.7	197	60.9	64.3
	186.79	191.7	197	112	15.3
	187.29	191.7	198.5	109	12.5
	187.98	191.7	198.5	101.5	5.5
	188.52	191.7	198.5	84.2	0
	189.1	191.7	198.5	63.9	0
	189.61	191.7	198.5	36.1	0
	190.21	191.7	198.5	12	0
	190.81	191.7	198.5	12	0
	191.42	191.7	198.5	12.8	0
	192.03	191.7	197	12.8	0
	192.52	191.7	197	12.8	0
	193.03	191.7	197	12.8	0
	193.69	191.7	195.5	12.8	0
	194.3	191.7	195.5	12.8	0
	194.83	191.7	194	12.8	0
	195.34	191.7	194	12.8	0
	195.85	191.7	192.5	12.8	0
	196.45	190.2	189.6	12	0
	197.05	187.2	186.6	12.8	0
	197.65	184.2	183.6	12.8	0
	198.15	181.2	180.6	12.8	0
	198.67	175.2	174.6	12.8	0
	199.26	137.6	137.3	12.8	0
	199.92	130.8	129.9	13.5	0
	200.48	122.6	120.9	14.3	0
	201.08	118	116.4	12.8	0
	201.68	182.7	180.6	30.1	0
	202.29	187.2	186.6	13.5	0
	202.88	180.5	179.1	13.5	0
	203.38	178.2	177.6	12.8	0
	203.89	171.4	170.1	18.8	0
	204.39	169.2	167.2	43.6	0
	204.99	179.7	179.1	45.1	0
	205.53	182	180.6	36.1	0
	206.16	184.2	183.6	67.7	0
	206.71	187.2	186.6	60.9	0
	207.31	188	186.6	31.6	0
	207.92	188	186.6	30.8	0
	208.41	188.7	188.1	54.9	0
	208.91	191	191	75.2	0
	209.43	191.7	194	57.1	0
	210.02	191.7	195.5	35.3	0
	210.53	191.7	194	13.5	0
	211.13	191.7	195.5	12.8	0
	211.8	191.7	195.5	13.5	0
	212.36	191.7	194	13.5	0
	212.93	178.2	177.6	13.5	0
	213.45	179.7	179.1	13.5	0
	213.94	180.5	179.1	13.5	0
	214.45	179.7	179.1	13.5	0
	215.05	179.7	179.1	21.8	0
	215.65	180.5	179.1	12.8	0
	216.26	180.5	179.1	13.5	0
	216.76	179.7	179.1	13.5	0
	217.26	179.7	177.6	13.5	0
	217.94	178.9	177.6	13.5	0
	218.49	173.7	171.6	13.5	0
	219.07	172.2	170.1	31.6	0
	219.58	175.2	174.6	31.6	0
	220.08	178.2	177.6	31.6	0
	220.69	178.9	177.6	31.6	0
	221.3	179.7	177.6	30.8	0
	221.89	179.7	177.6	27.1	0
	222.49	179.7	179.1	39.8	0
	223.1	180.5	179.1	39.8	0
	223.76	181.2	179.1	31.6	0
	224.35	180.5	179.1	14.3	0
	224.92	179.7	179.1	12.8	0
	225.51	178.2	177.6	13.5	0
	226.02	178.2	177.6	21.1	0
	226.63	175.9	174.6	30.8	0
	227.22	178.2	177.6	36.1	0
	227.82	179.7	177.6	36.1	0
	228.33	179.7	177.6	27.8	0
	228.93	179.7	179.1	26.3	0
	229.44	179.7	179.1	25.6	0
	230.11	179.7	179.1	25.6	0
	230.64	180.5	179.1	25.6	0
	231.24	180.5	179.1	35.3	0
	231.85	181.2	180.6	36.1	0
	232.45	182	180.6	30.8	0
	233.05	182	180.6	25.6	0
	233.56	182.7	180.6	24.8	0
	234.09	182.7	182.1	28.6	0
	234.66	183.5	182.1	37.6	0
	235.17	184.2	183.6	36.8	0
	235.86	184.2	183.6	38.3	0
	236.48	185	185.1	32.3	0
	237.08	185.7	185.1	31.6	0
	237.58	186.5	185.1	30.8	0
	238.18	186.5	185.1	25.6	0
	238.7	186.5	185.1	17.3	0
	239.29	185.7	185.1	12.8	0
	239.9	184.2	183.6	13.5	0
	240.49	184.2	183.6	30.8	0
	241.1	185	183.6	34.6	0
	241.65	185.7	185.1	36.1	0
	242.27	186.5	185.1	34.6	0
	242.81	186.5	186.6	34.6	0
	243.31	187.2	186.6	35.3	0
	243.92	188	186.6	34.6	0
	244.52	188	188.1	34.6	0
	245.12	188.7	188.1	31.6	0
	245.62	187.2	186.6	13.5	0
	246.23	186.5	185.1	12.8	0
	246.73	185.7	185.1	13.5	0
	247.34	183.5	182.1	13.5	0
	248	180.5	179.1	13.5	0
	248.54	157.1	155.2	12.8	0
	249.04	133.8	132.8	12.8	0
	249.65	130.8	129.9	24.1	0
	250.17	136.8	135.8	15	0
	250.76	127.8	126.9	12.8	0
	251.26	123.3	122.4	12.8	0
	251.77	121.8	120.9	24.8	0
	252.36	123.3	122.4	30.8	0
	252.97	124.8	123.9	30.1	0
	253.64	126.3	125.4	24.8	0
	254.25	127.1	125.4	15	0
	254.78	127.8	126.9	13.5	0
	255.28	126.3	125.4	12.8	0
	255.88	123.3	122.4	12.8	0
	256.5	121.1	119.4	12	0
	257.09	129.3	128.4	58.6	0
	257.7	175.2	173.1	13.5	0
	258.3	163.2	161.2	14.3	0
	258.9	171.4	170.1	53.4	0
	259.42	181.2	179.1	48.9	0
	260.09	185	183.6	48.9	0
	260.62	187.2	186.6	34.6	0
	261.22	189.5	188.1	40.6	0
	261.82	191.7	191	51.1	0
	262.42	191.7	195.5	61.7	0
	263.02	191.7	197	56.4	0
	263.65	191.7	197	53.4	0
	264.24	191.7	198.5	51.1	0
	264.84	191.7	201.5	50.4	0
	265.46	191.7	204.5	67.7	0
	266.11	191.7	206	93.2	58.8
	266.64	191.7	206	191.7	90.2
	267.16	191.7	206	188	89
	267.76	191.7	201.5	92.5	0
	268.36	191.7	209	12	0
	268.97	191.7	204.5	46.6	0
	269.58	191.7	204.5	158.6	95.3
	270.17	191.7	209	191.7	87.5
	270.79	191.7	206	188	95.3
	271.39	191.7	203	180.5	95.3
	272.04	191.7	200	170.7	95.3
	272.58	191.7	206	10.5	0
	273.18	191.7	204.5	12	0
	273.69	191.7	207.5	12	0
	274.29	191.7	204.5	12	0
	274.89	191.7	198.5	12	0
	275.5	191.7	198.5	12.8	0
	276.01	191.7	197	12.8	0
	276.6	191.7	197	13.5	0
	277.1	191.7	197	12.8	0
	277.68	191.7	195.5	12.8	0
	278.28	191.7	195.5	12.8	0
	278.8	191.7	194	13.5	0
	279.32	191.7	192.5	12	0
	279.92	190.2	189.6	12.8	0
	280.54	185.7	185.1	12.8	0
	281.13	182	182.1	12.8	0
	281.74	178.9	177.6	12.8	0
	282.33	157.9	156.7	12.8	0
	282.84	136.1	135.8	12.8	0
	283.34	130.1	129.9	12.8	0
	284.04	121.1	119.4	13.5	0
	284.65	121.8	120.9	15	0
	285.15	120.3	119.4	13.5	0
	285.65	116.5	114.9	15	0
	286.16	132.3	131.3	12.8	0
	286.78	133.1	131.3	16.5	0
	287.36	133.1	131.3	39.1	0
	287.88	135.3	134.3	66.9	1.2
	288.47	162.4	161.2	66.2	0
	289.08	178.9	177.6	35.3	0
	289.75	179.7	179.1	35.3	0
	290.34	181.2	180.6	54.1	0
	290.88	184.2	183.6	69.2	0
	291.39	187.2	186.6	77.4	0
	291.89	191	189.6	71.4	0
	292.49	191.7	191	38.3	0
	293.01	181.2	180.6	13.5	0
	293.61	156.4	155.2	13.5	0
	294.2	155.6	153.7	13.5	0
	294.81	132.3	131.3	13.5	0
	295.31	124.8	123.9	13.5	0
	295.98	126.3	125.4	26.3	0
	296.53	130.1	128.4	70.7	72.5
Does this help?
Also I have just noticed that on a run last night the requested boost is completely different to the other night!
new:
old:
strange
A/f looks fine - running very fractionally richer than requested at the top end.
I'll opt for the first 20 seconds of 114
The pink line is the target load, the yellow line is the adjusted target load. The blue line is the actual load, . Duty cycle is at the bottom.
Is that a third gear run? If so, I'd say where actual is meeting target is maybe the power run and the car hasn't shown it's fault here...........
What would that suggest the problem to be Dave?
p.s thanks again, your time is very much appretiated.
Hmmm, cant remember to be honest.
Tell you what....
I will do 114 again in a bit and 100% make sure it did it (badly) on the run.
I'm puzzled because on the 114 run, load is decaying away as on 115 before, but in comparison the wastegate is closing fully again on 114, whereas it was different on prev run.
Log 107 with 114 this time, just to pick up prm.
Here are 3 new 107/114 runs
Code:
	Group A:	'107				Group B:	'114				Group C:	 Not Running
		Idle Speed	O2 Control	n/a	Diagnostic		Eng Load Call	Corr. Load	Engine Load	Bypas Dut Cyc/0-100%
	TIME	700-820 RPM	-23.23	n/a	Sys. OK	TIME	<=150%	<=150%	15-150%		TIME
Marker	STAMP	 /min	%			STAMP	%	%	%	%	STAMP
	1.36	1280	0.8	        	Test OFF	0.76	112.8	111.9	32.3	0
	2.64	1400	-5.5	        	Test OFF	1.96	115	113.4	75.9	95.3
	3.77	1600	-1.6	        	Test OFF	3.2	121.1	119.4	89.5	95.3
	4.88	1800	-1.6	        	Test OFF	4.28	130.8	129.9	97.7	95.3
	6.09	2080	-3.9	        	Test OFF	5.48	167.7	165.7	109.8	95.3
	7.29	2400	-3.1	        	Test OFF	6.69	185.7	185.1	134.6	95.3
	8.47	2800	0	        	Test OFF	7.8	191.7	194	170.7	95.3
	9.61	3280	18	        	Test OFF	9.07	191.7	200	191.7	86.3
	10.71	3760	20.3	        	Test OFF	10.12	191.7	209	191.7	80.4
	11.92	4280	20.3	        	Test OFF	11.32	191.7	204.5	191.7	82.4
	13.14	4680	15.6	        	Test OFF	12.54	191.7	210.4	191.7	85.1
	14.42	5080	20.3	        	Test OFF	13.74	191.7	206	187.2	95.3
	15.56	5440	20.3	        	Test OFF	15.01	191.7	201.5	179.7	95.3
	16.76	5800	19.5	        	Test OFF	16.15	191.7	197	164.7	87.8
	17.86	6040	10.9	        	Test OFF	17.26	191.7	192.5	144.4	72.5
	19.07	6280	15.6	        	Test OFF	18.48	191.7	189.6	148.1	88.6
	20.33	6520	21.1	        	Test OFF	19.68	189.5	188.1	151.9	78
	21.49	6720	10.2	        	Test OFF	20.97	188	186.6	139.8	67.1
	22.69	6840	9.4	        	Test OFF	22.1	188	186.6	131.6	64.3
	23.9	7000	9.4	        	Test OFF	23.3	188	186.6	130.1	66.3
	25	5440	0	        	Test OFF	24.4	188	186.6	13.5	0
	26	4480	0	        	Test OFF	25.5	191.7	207.5	12	0
Thursday	17	July	2008	20:35:05
06A 906 032 HN		1.8L R4/5VT         0002
	0.61	1200	-3.1	        	Test OFF	0	109.8	109	48.9	0
	1.71	1280	-1.6	        	Test OFF	1.21	112.8	111.9	59.4	0
	2.72	1400	-3.9	        	Test OFF	2.21	115.8	114.9	83.5	95.3
	3.96	1600	-0.8	        	Test OFF	3.39	121.1	119.4	91	95.3
	5.03	1800	-1.6	        	Test OFF	4.53	131.6	129.9	98.5	95.3
	6.24	2040	-3.9	        	Test OFF	5.64	161.7	159.7	108.3	95.3
	7.44	2400	-3.1	        	Test OFF	6.84	184.2	183.6	131.6	95.3
	8.65	2800	0	        	Test OFF	8.06	191.7	194	172.2	95.3
	9.92	3320	18.8	        	Test OFF	9.32	191.7	198.5	191.7	84.3
	11.08	3840	20.3	        	Test OFF	10.46	191.7	207.5	191.7	81.2
	12.27	4320	20.3	        	Test OFF	11.68	191.7	204.5	191.7	82.7
	13.28	4680	16.4	        	Test OFF	12.77	191.7	210.4	191.7	86.7
	14.39	5040	14.8	        	Test OFF	13.78	191.7	206	188	82.7
	15.67	5400	20.3	        	Test OFF	15.02	191.7	201.5	181.2	95.3
	16.8	5720	19.5	        	Test OFF	16.22	191.7	197	169.9	95.3
	17.91	5960	18.8	        	Test OFF	17.4	191.7	192.5	159.4	74.9
	19.02	6200	19.5	        	Test OFF	18.51	191.7	189.6	154.1	95.3
	20.13	6440	20.3	        	Test OFF	19.52	190.2	188.1	151.9	78.8
	21.3	6600	8.6	        	Test OFF	20.73	188	186.6	142.9	67.5
	22.55	6760	8.6	        	Test OFF	21.93	188	186.6	135.3	65.5
	23.74	6920	6.3	        	Test OFF	23.15	188	186.6	133.1	69
	24.86	7040	3.9	        	Test OFF	24.25	188	186.6	145.1	77.3
	25.96	5800	0	        	Test OFF	25.45	188	186.6	9	0
	27.22	4120	0	        	Test OFF	26.56	191.7	206	12.8	0
	28.36	3560	6.3	        	Test OFF	27.82	191.7	200	10.5	0
	29.57	3200	0	        	Test OFF	28.97	191.7	201.5	11.3	0
Thursday	17	July	2008	20:39:50
	0	1360	12.5	        	Test OFF	0.6	115.8	113.4	29.3	0
	1.28	1320	-5.5	        	Test OFF	1.82	115.8	113.4	22.6	0
	2.41	1320	-2.3	        	Test OFF	3.03	115	113.4	22.6	0
	3.62	1320	-1.6	        	Test OFF	4.12	115	113.4	22.6	0
	4.62	1320	-1.6	        	Test OFF	5.25	115	113.4	22.6	0
	5.83	1320	-1.6	        	Test OFF	6.43	115	113.4	48.9	95.3
	7.11	1400	-3.1	        	Test OFF	7.67	121.1	119.4	87.2	95.3
	8.25	1600	-2.3	        	Test OFF	8.86	133.1	131.3	97.7	95.3
	9.35	1800	-2.3	        	Test OFF	9.86	163.9	162.7	109	95.3
	10.46	2040	-3.9	        	Test OFF	11.06	185	183.6	132.3	95.3
	11.67	2400	-4.7	        	Test OFF	12.28	191.7	194	172.9	95.3
	12.95	2800	-2.3	        	Test OFF	13.53	191.7	198.5	191.7	84.3
	14.08	3320	18.8	        	Test OFF	14.68	191.7	207.5	191.7	80.8
	15.29	3840	20.3	        	Test OFF	15.89	191.7	203	191.7	82.7
	16.4	4280	20.3	        	Test OFF	17	191.7	209	191.7	85.1
	17.61	4720	18	        	Test OFF	18.21	191.7	204.5	187.2	84.3
	18.87	5120	20.3	        	Test OFF	19.47	191.7	200	191.7	89
	20.01	5480	20.3	        	Test OFF	20.52	191.7	197	184.2	72.5
	21.13	5760	10.2	        	Test OFF	21.73	191.7	192.5	145.1	65.1
	22.35	6000	7.8	        	Test OFF	22.93	191.7	189.6	160.2	78.4
	23.45	6240	7.8	        	Test OFF	24.06	189.5	188.1	139.1	68.6
	24.66	6440	7	        	Test OFF	25.28	188	186.6	169.2	71
	25.87	6600	19.5	        	Test OFF	26.47	188	186.6	140.6	67.5
	27.07	5720	0	        	Test OFF	27.67	191.7	207.5	12.8	0
	28.27	4160	0	        	Test OFF	28.86	191.7	201.5	11.3	0
	29.47	3800	3.1	        	Test OFF	29.97	191.7	203	11.3	0
	30.58	3560	4.7	        	Test OFF	31.26	191.7	203	11.3	0
It doesnt seem as bad as usual but run 3 seemed a touch worse than other 2.
To possibly save you some time here is the graph for it:
You can really see the up and down on the WG duty now. Might be worth trying another valve to see if that makes any difference.
Nice logs tho, nice to see someone listening, making the effort and posting them up nicely. :D
Do you think we should buy a new N75 then?
EDIT...
Also why would the requested boost line somtimes change? Sometimes it sort of follows the boost line down and other times it stays flat and high.
