Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
by law any car fitted with xenons must have auto leveling and washers
dont forget the lights on self test once the engine has started, not on ign on, and the afs only works above 15mph.
if its not working properly there should be an alarm, try starting in the dark up against a wall. i'm sure itll be working ok.
Does anyone know if the xenons can be retro fitted or do they have to be done at a dealers?
I actually don't find them overly bright either, sat next to a couple of BMW's and theirs always appear brighter than mine when compared.
I agree Tam. the ones in my '03 ST170 appeared alot brighter IMO.
Anyway got mine to a dealers today(not where i bought it) for a diagnostic on the xenons. Told them they dont self test everytime (yesterday morning no, last night yes) and dont 'appear' to follow the road when i turn. ALso mentioned that they appear to be set too low.
They plugged the diagnostic in and it was showing no errors. They tell me that it isnt suppossed to do it everytime just and i quote 'some times'. Told them i thought it needed to judge the weight of the car each time so was required everytime lights turned on and they just shrugged their shoulders. Sorry we dont know....what sort of answer is that??
Customer service is not their strong point, charm school was definatley shut when they got there
So back to square one, think i'll try another dealer.
Mine definately self test the first time I turn them on each day, if the car is stationary.
You can visibly see them moving if you suddenly turn the steering wheel.
mine do it every time too. it also does it while moving (if you pull off as soon as the engine is started, it will still run its routine).
i smell stealer BS.
Just to chip in that mine also do the dance everytime the lights are switched on and the ignition is on... Except if the car is moving and the lights come on via the convenience function - I haven't tried switching them on manually whilst driving...
Do you have convenience?
