dee1
Hi guys im quite new to this so just wondering what you's recommend for a upgraded brake kit?
I have a 1.9tdi remapped to 150bhp with 17 inch rs4 alloys
I have some tarox b32 6 potters which are fantastic! Used with corsa+ pads and dot 5.1 fluid i suffer no fade or vibration on hard track use..... ohh they stop you rather well too! They do need a 17'' wheel with the 312mm discs:) The normal route is to buy some bigger brakes off a audi tt i believe cos it's cheaper. ;)
The easy way is to go for a 312mm setup from an Audi TT. You need calipers, caliper carriers and longer brake lines, 312mm discs and pads for the calipers. The TT-shop LINK can sort you out! I will be doing this when I have to replace my standard pads and discs as the carriers and calipers are only about £110 from the TT-shop.
What bhp did your car start off at? If it's any less than a PD130, then you'll need to change hubs if you want to upgrade to 312's i think.
it started as a pd100. Could you point me in the right direction then?
You will need hubs from a pd130 sport or FR or from a fabia VRS
