vwbassett
Joined the Dark Side
Aug 13, 2007
960
53
Surrey
Hi, Ive got an autometre gauge and dont want to use the supplied hard hose. What hose is recommended to replace it and how have you connected it to the gauges threaded sensor?
cheers
I used 4mm as its a better more readily availble size.
The actual hose is made from high temperature nylon so i could run it along the strut brace but i realise this is not availble to everyone so silicon taken a lower temperature route would be fine.
I changed the brass fittings on the gauge to suit the larger pipe and got a 4mm olive too.
The plastic shroud and tee will accept 4mm piping as i have an autometer gauge to and its what i am using
I got them from where i used to work.
They are just normal brass compressed air fittings off some press tools.
Any tooling wholesaler should have them
