Dan20vt
Hi folks been having a lot of trouble with my car the last few days at first i replaced a coil then maf plus plugs and i still have no power the n75 is reading 100% and the maf about 100 i think just noticed the turbo actuator is not moving at all does this have anything to do with limp mode?
only fault showing on vag com now is Charge Pressure Control: Negative Deviation
Cheers Dan
Cheers mate im trying to get seat to pick it up today its giving me to much greif now lol if they dont i will take the pic...
Does anyone no if the actuator should actually move when you rev the car up in limp mode mine dosent feel seized but its not moving when the car is reved up..plus engine light is on and in limp mode
your actuator will only move if your on boost, ie, moving, unless you ride on the clutch and rev.
Your on negative deviation mate, means your requesting too much and its not delivering, e.g. boost leak, take martyns advice :)
Cheers for the advise, i just spent an hour at seat with a technician and its lookin like its goin to be one of them nightmair faults to find.
possible cat blocked anyway there will be further investigation done tomorrow now Cheers
if the n75 is pegged at 100% and ur seeing neg. dev. u have a v serious boost leak between the turbo and inlet mani , do you hear whoosy noises, have u traced all the pipes checking for splitsor open joints
a car stationary does not come under boost weather revved or not mate the only way to find a boost leak under load is on a rolling road i.e jimmy did this on his at westec
I had a boost leak yrs ago on an uno turbo and the rolling road guy sprayed wd40 around all my hoses to find where it was coming from.As soon as it got drawn in the revs went t*ts up.
Also another time i had to take the airfilter off and place somthing flat over the induction hose,if it keeps running you have a leak.
Im not sure these will work on your car but might be worth a shot if you have'nt done so already.And would rule out a boost leak atleast.
