Hi all,
New on here as I have a bit of a
problem...
In short for the last 3 months my 2001 Seat Leon Cupra ( 180) has started rattling on startup. Muffled when cold with more of a whir like a pully isnt happy about being turned and much more clattery when warm. The hotter the louder the clatter. Only for a few seconds on startup and it stops as soon as you rev is slightly. After the first
garage... replaced the starter motor - still same noise, then alternator pulley and tensioner - still same noise... I took it to a specialist ( independent) who at first had the same issue identifying the
problem but eventually diagnosed it with a failed Camshaft Variable adjuster? When I asked them to explain they said it was a tensioner attached to the Cam Chain that adjusted in line with timing etc. Im not a mechanic so said ok how much...
£1'126...
including vat. My only issue with this is that surely if the tensioner had failed it would do it all the time? and I also thought the cam was belt driven on these? Anyway dont know if anyone can
help with any advice but Im reluctant to spend such and amount of money on a fault I have never heard of particularly when at the last
service I had the cambelt done ( 60k) water pump etc etc along with the coil packs that set me back £800 4 months ago which need doing again as part of the same job?
My sister and dad both have different Audi's with the same engine and theres are well in 3 figures mileage wise with no issues...
