Perhaps I should stop worrying then.
Is it true that you get less PSI in cold weather because the air is denser and therefore more "efficient" wth pressure?
I ask because my 22psi was seen in the height of summer. I can't remember actually checking the guage since then
OK, cleaned up the N249, totally removed unused hoses to remove any possibilty of leaks in unwanted pipage :D
It now feels much better to drive! But boost is the same figure max 18psi. I repeat though it pulled very well through the gears.
Also, that weird "tsh tsh tsh tsh" dump noise has gone, now its just the usual tshhhh!
I changed the N75 for another and it still drove just as well but still didn't exceed 18psi boost.
I think I can rule out MAF becuase MAF flow looks healthy and it drives well.
I can hear what sounds like a small blow in the exhaust - can this cause a boost leak if its pre cat?
Am i just being paranoid? I'm nclined to give up ripping the car to bits just because the numbers seem off, but I can recall a time I could peak boost to 22psi :confused:
what method did you use to clean it? i want give mines spring clean :confused:
