I've tried that loads of times m8. I think limp mode is only 5psi max isn't it? I'm getting much more than that, just less than i'm used to.
Read the faults this morning - had 17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-10 - - - Intermittent
and the usual 17704 error in mapped cooling system. Although this one is no longer stated as being intermittent - so I guess its permanent and therefore more serious? For clarity, the car doesn't overheat, but sometimes it doesn't budge above 60 even after an hour or so with some spirited blasts involved.
block 118 (boost duty) never goes above 95% so I guess that its definately not a boost leak. (actual always meets requested too)
