Car swerving when heavy breaking..
Georgie
WADDA YA WANT.. EH?!
Nov 27, 2005
451
FLEET
this has happened several times today where i have been doing a little more than the recomended road limit and because of people not looking where they are going have needed to drop 50mph+ in one go.
when i have put my foot down the car will swerve heavly from one side to another, i havent noticed this before like this and am fairly convinced it isnt normal.
any ideas.
Georgie
Nov 27, 2005
451
FLEET
i had the car serviced 2 weeks ago for is 30K service, a friend drove my car and said they were too soft.. so had them bled, made a wee bit of difference but not much.
when it was serviced they said breaks were 50% worn and would need changind at next service.. but i do plan on having them upgraded by then so left it.
just a little un nerving when i know i may need to stop very quickly to avoid a accident and then the stopping its is gona cause another one as i plow in to the side of another car!
cstevens
202
I am having this same problem at the moment, Leon FR 8000 miles. Car is going in for some niggles, rough sounding and speaking brakes being one of them.
Normal braking feels find, however say 80mph heavy braking and I am swerving, I check my tyres very regulary and they are fine, I put it down to high winds on one occasion, but have experinced it about 6 times now.
Its defnitely not trammlining either, have had this a lot in the Celica and MR2, this is not pulling to one side, its swerving both ways.
Georgie
Nov 27, 2005
451
FLEET
i am presuming since track day since i never noticed it before, but say i am doing 80 and i drop to 40 cause some plonker puts a speed camera on the road i will have issues.
but normal breaking is fine.
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
It could be a sticking caliper throwing it off balance, I had this happen with my Ibiza and it would pitch the car the same direction at speed.
Is this one of the things you picked up from the trackday?
Edit: are your Koni dampers adjustble?
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
No good in a box are they?:p
It's likely to be one of 3 things - Tyres, Brakes & Shocks
If its not resolved by monday, I can perhaps take look & see what I can make of it?
maybe it's because SEAT brakes are **** !!!!!!!!!
sorry, they're ok when you stand on the pedal, but they're so spongy, and only work after a lot of pedal travel?
Compared to the Pug brakes, they're awful. But then, i've got ABS,EBD,and EBA.
all i have to do is put the weight of my foot on the pedal, and the car stops by itself. If i stand on the pedal, IT HURTS. Highway code states that braking from 60mph takes 240ft. i can stop from 60mph in less than 100ft :)
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
is it swerving from left to right consistantly? id have thought if it was a caliper issue or shock or tyre it would go always to the same side ( where the faulty bit was) ?
if its almost equally left to right then could the abs sensor be playing up as already said?
id get a garage to check it. bad brakes = broken car
Si
Southern MoFo!
Aug 21, 2003
383
Bournemouth
www.westover.org.uk
Brembos are fine :bleh:
hehe:D
Sorry!
Georgie
Nov 27, 2005
451
FLEET
wont be resolved by monday as every where is now closed.
car was serviced 2 weeks ago now, and when a friend drove it he said that the breaks felt too soft. coudl get the pedal to the floor easly, took it to wheelbase in hersham and they bled them suspecting air in the brakes. made a little bit of a diference. took the car to camberly seat and they checked it over telling me it was fine and there was no problem, have it in writing. when it was at wheelbase they said they recon its a internal leak in the ABS thing as they had had 3 cars recently all VAG all with the same problems and the result was they all had a internal leak in the ABS sensor.
given that i have done a track day since my service and i am sure there was some element of cooking going on there was a existing problem before hand and now its worse. its fine under normal breaking, but if there comes a time where i may need to use them, and use them well i dont want to have to worry about avoiding the twat infront of me or to the side of me and then scaring my self sh!tless as i also have to contend with the car swerving.
Reg
Professional Detailer
Oct 10, 2005
962
Berkshire
Sorry, but I don't agree with you there. Just because you can touch the pedal lightly and stop dead does not make them 'good brakes'. They are just totally over-servoed, meaning the pressure you place on the pedal is magnified many times at the caliper.
Driving a car without servo assisted brakes is so refreshing. You can actually feel what the car is doing, rather than the numb feeling in 99% of modern cars where you smash your face on the steering wheel should you dab the middle pedal a little hard.
Good brakes should be measured by stopping distance, feel and lack of fade after repeated heavy duty stops. My old Mk1 Golf was said to have '****' brakes by people who drove it for the first time. But it wasn't a lack of brakes - that car could stop straight and true very quickly, and with decent pads and fluid resisted fade even on track but the pedal needed more pressure than they were used to. It could easily lock the front wheels at any speed, so therefore didn't need to clamp the pads onto the disks any harder.
