i think i got coil pack problem, will find out tomorow. only had the car about two months. i thought it would be reliable because it was made by vw.....
Dont think theres a guide, but its an easy enough fix.
1. Make sure the actual water/mix in the bottle isnt frozen.
2. Make sure the nozel is clear, so thats not blocking the flow.
If both are ok, then get someone to spray the rear washer for 10 seconds or so and you have a look around.
1. Check behind the front n/s wheel, you might see water/mix dripping down which leads to the fault in the bay. Most likely the pipe underneath the airbox has blown apart. Remove the airbox, fit the 2 "ends" of the pipe together and tighten the jubilee clip.
2. Check the cloth trim on the o/s in the boot. If this is soggy then it will have popped off behind that. I think you need to remove the plastic at the top of the seatbelt to get into it. Should be easy enough from there.
3. Check the boot plastic, there could be water dripping from that. In this case the pipe has popped off where it joins the rear wiper/washer. Remove the bootlid plastic and attach the pipe accordingly.
Cheers, dont think its because its frozen because the fronts still work? il have a go at the other stuff though and see if that works![]()
08 reg 1.4 sport.
ECR light and engine management light on for 2 days, go to garage, lights go off the minute I leave the garage, and "no fault found" on diagnostic equipment.
Also, rear washer pipe put back on again (2nd time)
hi i was wondering if anybody has had problems with igition coils failing on there cars i have had three go in the space of a month, and they were not on the same cylinder, have put an after market code reader on her and it just has the one fault of the coils failing, any ideas as what it could be if it is not just the coils have checked the plugs and they look ok.
